Question about Canon Optura 100MC Mini DV Digital Camcorder
Zoom not functioning
This camera is over 5 years old and i have taken very good care of it. my wife took it to our sons school for a play and noticed the zoom no longer works. i dont notice anything different about the camcorder and i can't find a reset button anywhere. any ideas would be apreciated. thanks
SOURCE:
sonysonyman
  • 71 Answers
SOURCE: Canon ZR300 record button no longer works
hi sir just two things to do first 1- restore to factory setings from the menu and check if it is solved 2- if not just try to see does the knub is in its reguler state if yes so you need to replace it
Posted on May 08, 2007
SOURCE: Canon S70 does not work
I was experiencing the same problem - I think the Button and Zoom had become jammed down slightly. I simply lightly applied pressure lifting the surround of the button up! My camera is now working perfectly.
Posted on Jul 13, 2007
t00nz
  • 4738 Answers
SOURCE: Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Posted on Dec 08, 2007
t00nz
  • 4738 Answers
SOURCE: Red/White Lines On Photos and LCD
Sorry I didn't see this sooner. This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info: http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
  • 6 Answers
SOURCE: Playback error
I suspect the zoom is also a problem on the camera record also and not just in playback mode. Not certain as to why this happens but I have solved this problem on two MVX250i's by doing the following:
Remove the battery, release the palm strap (velcro) and open the cassette door. remove the two small screws, one in the front and one in the rear of the switch panel holding the zoom button. remove also the two screws it the face of the door cover. Grip the ends of the switch panel with one hand and raise it slightly. At the same time pull lightly on the plastic door cover in a slightly downward direction and the three lugs holding the cover should release. The lower edge of the cover is held with a hook under the metal door and a small metal hook on the lower corner by the strap. The speaker is mounted on the plastic cover and connected by printed cables. Take care not to damage these. The printed cable is attached to the door with an adhesive pad which can be carefully removed and the speaker will then fall from its socket. Close the cover and re-fit the battery. Check if the fault still occurs. On both my cameras the fault disappeared at that point and remained solved when re-assembled. I suspect it to be a poor joint on the printed cables where they enter the sockets at each end.Moving the cables slightly seemed to be the solution. To get to the lower end connection the cassette mechanism has to be parted from the camera. Not an easy job. The top end connection is not easy to access either. When re-fitting the speaker, make certain it is seated correctly in its socket. If it is not then it will short against the metal door.
This operation requires a very small screwdriver, a steady hand and good eyesight/lighting. Re-assembling is never as easy as dismantling so beware. Needless to say I will take no responsibility for these suggestions should it result in your not being able to reassemble it or in your damaging it in the process.
Posted on Dec 18, 2007
Hi, I have had my Finepix 6900 Zoom for more than
A camera (or any electronic equipment) at ten years old is nearing the end of its useful life. Best to replace it with a newer updated model
Mar 29, 2017 | Fuji FinePix 6900 Zoom Digital Camera
Stuck zoom button on Nikon Coolpix S6100
Even though you have taken good care of your camera it does not mean that parts wear out, switches just go bad after use. Your camera will require repairs at a shop to correct this problem. This is NOT a user fix.
Jan 25, 2013 | Nikon Coolpix S6100 Digital Camera
All of my shots are grainy--really grainy. My old 8 mpx camera took beautiful, tack-sharp photos. This is 14 mpx and it looks terrible. Someone suggested that maybe the contrast needed to be adjusted ...?...
Unfortunately with higher mpxs sometimes you pay for it with higher noise levels. The smaller pixels are more sensitive and can cause noise. A couple of things you can do to help control the noise is make sure your pictures not underexposed, you may need to bump up you exposure compensation a little as long as you don't end up too bright.
You can also try to shoot with the lowest ISO setting your camera has. High ISO = NOISE!
Last you can run your photos through a noise reducing program such as"Noisware" their community edition is free. http://www.noiseware.com/download_nwsa.aspx
PS Contrast settings will do nothing for noise.
May 03, 2011 | Kodak EasyShare Z981 Digital Camera
Photography Class Camera
Hello, depending on the class he is taking you may find that a normal digital camera will suffice. Most camera classes and courses now use digital, unfortunately the old film cameras are becoming a thing of the past. If your son is a mad keen photographer then I would consider investing in his future and buy him a good quality digital SLR. I hope this is somewhat helpful.
Nov 04, 2009 | Minolta Maxxum 5000 35mm SLR Camera
Can you please tell me why the Sansa Shaker is not recommended for kids under 8 years old. I'd like to buy it for my 5 year old son, and wonder if it's OK if he simply listens through the speakers rather...
It is totally fine for him to listen through the speakers.The mp3 for me wasn't that good, mostly because some of my songs would download and the mp3 player wouldn't play the songs. It would probably be fine for your 5 year-old, maybe the company thinks you have to be 8 and up to be careful and not brake an mp3. Other than that, I have no clue.
Sep 08, 2009 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
I have a Minolta Maxxum 5000i. It is dead
Check to see if there is a button battery in another compartment. Usually the "big" battery is for the flash and some other functions but there may be another one that serves basic functions like aperture and shutter operation.
Sep 02, 2009 | Photography
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
Zoom (W-T) function not working
tienen ustedes expertos latinos que hablen espanol.
Did you have experts speak spanish
Oct 17, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Canon SD550 Digital Zoom Not Working
Digital Zoom is best ignored in any camera it simply blows up a section of an image already taken, You can do that far better with an image editor in the computer. As for the Optical Zoom - it does indeed seem to be repair time- As it is only a year and half old- may be Canin will be sympathetic and offer a cheap swap out.
May 12, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon Optura 100MC Mini DV Digital Camcorder Logo
80 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
