Question about Briggs & Stratton Garden
Won't start , spiting gas bach thu crab , flooding engine
  • 1 more comment
  • Leon Cook
    Leon Cook Apr 25, 2010
    yes i need to clarify this , its not the crab as i just put a new one on i
    bought tractor from another party , it was pop-in and back firing and
    of course spiting gas back, but was running i order new carb put it o
    n and at 1st it ran good for about 20 min then started the same as before ,
    now i can't get it to start at all unless i disconnect the fuel line and w
    ait awhile , then of course only till it drains bowl, it is blowing f
    uel out just turning the motor over
  • Leon Cook
    Leon Cook Apr 26, 2010
    Comments:
    Apr 25, 2010 -
  • Leon Cook
  • 821 Answers
Hello,This is normally caused by a defective inlet needle. The inlet needle has a rubber tip, actually it's viton. With the mower sitting empty that long the viton tip is probably hard and brittle so when the float rises in the carb bowl the needle is not sealing and shutting off the fuel flow. You can try removing the float bowl and replacing the inlet needle. You can do this without removing the carb. If enough gas got into the engine you may have to change the engine oil. OR checked all the usual suspects by insuring that the battery is fully charged and will provide the starting load, the spark plug is connected and none of the safety devices like having the machine in gear or the blades engaged are causing the problem,the next place to check is the solenoid.the solenoid is usually easy accessible and is an electromagnetic switch that engages when you energize the ignition,by turning the key to the start position. If you lift the engine cowling and look to the rear of the engine you will see the solenoid. The positive (red) and negative (black) battery wires will be attached to it at heavy posts as well as some other electrical wires connected to smaller posts. First try gently tapping it with a rubber mallet.Sometimes this electromagnetically activated switch gets stuck. If that doesn't work, you can try jumping the solenoid switch. The safest way is to take your battery jumper cables and using just one of the jumper wires, connect one side to the negative post (black) on the solenoid and then touch the other side to the positive post (red) of the solenoid. Make sure your key is in the on position and the lawn mower is otherwise ready to start. Be careful that the jumper wires do not become tangled as the engine starts. Also, someone sitting in the seat to prevent any mishap is the recommended and safest procedure. thanks for using fixya, take care.
Posted on Apr 25, 2010
  • Hammid Disu Apr 25, 2010
    hello,please kindly state the problem so i will know how to answer it.
    thanks,take care.
  • Hammid Disu Apr 26, 2010
    hello,firstly,get a new spark plug and replace it with the one you are using and try to power it and see if the problem persist.you can as well follow the steps below....
    Inside the gas tank on a tube is a tiny filter and it plugs with junk, just buy a new one and put it on or you emptied the tank and put in some fresh, premium gasoline, then try to power it up.
    In addition,you can visit the site below for a more comprehensive solutions...
    http://www.thriftyfun.com/tf14752090.tip...
    wish you good luck,
    take care.
08 outlaw 90 no start clean carb run great 2 weeks cuts off few times start back then no start air cleaner bad clean crab no start plug drippin wet run 4 few gas hafe off
if the plug/s are wet , that is flooding and that is excessive fuel or float level , probably from a problem in the needle and seat area where the fuel supply is not being controlled
remove the needle and seat and clean all dirt and rubbish from the needle ans seat area
could come from rust and dirt in the tank so consider an inline fuel filter before the carby/s
Mar 05, 2016 | Polaris ATV
Ryobi 780 r won't stay running
replace the carb. You are flooding the engine because there is an internal leak that a carb kit won't fix allowing the gas to continue to flow
Feb 01, 2013 | Garden
Just ran out of gas in 1999 Kia Sportage...put gas in and still won't start. turns over but won't catch. fuel gauge is registering 1/4 tank. is it flooded? should i let it sit a few minutes then...
put foot flat to floor DONT pump the accelerater pedal turn on ignition turn over engine as soon as it starts take foot off pedal happy motoring..
Jan 12, 2013 | Cars & Trucks
Will not start appears no gas
The most common reason a car will crank but not start and you smell gas is you flooded it. Too much gas to the engine causes too rich a fuel mixture and the fuel won't ignite.Click this link below for more troubleshooting :---http://technoanswers.blogspot.com/2012/01/car-will-not-start-and-smells-like-gas.html
---------Thanks.
Jan 26, 2012 | Cars & Trucks
While trying to start the saw the compression is so great that it is near imposible to pull the start rope ....ie won't spin fast enough to start ... new plug ,,,, new gas .....no start ,,,tired arm...
If the carb is flooding it will fill the cylinder with fuel, this will cause a hydralic lock, making it near impossible to crank the engine, remove the spark pluf, turn the ignition off, crank the engine, if fuel pours out of the plug hole then it is well flooded, you will need to get a pressure test on the carb to check the needle is not leaking, this will be the quickest way to check the carb.
Sep 19, 2011 | Poulan 14" Chainsaw
19e412-0134-01 won't start. gas leaks out air
The float is stuck on the carb flooding the engine and leaking gas out of air filter. Remove the float bowl after the gas is turned of or drained. Thoroughly clean carb And bowl with carb cleaner. Reove the float {very carefully} if it is copper, shake it. If you here fuel in it then it is no good. If not then clean everything and reassemble. If it needs to be replaced, most small engine repair shops will have your parts.
Aug 28, 2011 | Porter Cable BSI550 W 5,500 Watt Generator...
The PB-250 will not start. It was purchased last year and used little. I have fresh gas and a new properly gaped OEM plug. I do have spark. The spark plug is wet with fuel. Can one flood the engine by...
It is very easy to flood this item mind you its easy to flood all petrol trimmers. If plug is wet simply turn the switch to off and pull cord at least 15 times you should get the engine to start coughing keep pull cord but do not turn the petrol on do not prime it either. It should catch. If it does not push the primer once and pull cord
May 31, 2017 | Echo Gas Blower 135 MPH390 CFM Blower...
My yamaha400se won,t start.I have a spark at the plug and when i take the plug out its wet with petrol. can you please help regards Paul
Sounds like it is a flooded engine from a carburetor that is allowing too much gas into the engine.
Feb 03, 2011 | 1981 Yamaha XS 400 SE
1990 vette dose not start.it cranks and i have spark and fuel. it will turn over if i spay some starting fluid in it
well then it not getting fuel into the motor,you may have a bad crab, the needle may be pluged or stuck closed, also make sure theres good gas in it, if gas is getting to carb then it the crab, may need a good rebuild,
May 10, 2010 | 1990 Chevrolet Corvette
B&S motor won't run 1981 model 422437
From what you describe it sound as though you have a bad valve, either the intake causing compression blowback or exhaust not opening.
Apr 26, 2010 | Garden
Garden Logo
116 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
