Question about Pool & Spa
Hi I hay a Hayward H400 pool heater. It is 2
Hi I have a Hayward H400 pool heater. It is 2 years old. It just started doing this. It starts and then after about 2 mins and it kicks on and off. It keeps cycling like this until I shut it off . Once it starts cyling like this, the cycles are short 5-10 secs. I need to shut it off to stop it. The control panel shows not error codes. Does anyone have any suggestions? Thank you.
  • 990 Answers
This is a water flow problem and will be the by-pass assembly in the water manifold. Or their may be an external by-pass wich will be a valve bridging the inlet and outlet pipes for the water. This valve if you have it should be 80-90% closed to force water through heater. Before you do anything be sure to check to be sure the filter and baskets are clean. Often this is the problem.
Posted on Apr 25, 2010
CAN A OLD STYLE H400 NATURAL GAS BE CONVERTED TO A LP GAS I HAVE A H400PED2 IT DIED IT IS NOT MAKE ANY MORE IF I FIND A H400 NATURAL GAS CAN IT BE CONVERTED
The last I checked a kit was available for this conversion.
I recommendyou call the Hayward technical support at 908-355-7995and they might be able to help you figure this issue out. Ihope this helps.
Sep 17, 2011 | Hayward H-series Electronic Gas Pool...
I can not turn off ob on the screen of my Hayward pool heater
I looked up the owners manual for the Hayward H400 heater and it did not list the "ob" indication. For this reason I would call the and they likely can help you out.
Please let me know how this turns out. Thank you.
Aug 30, 2011 | Hayward H-series Electronic Gas Pool...
Hi what size and kind of regulator do i need for my hayward propane H250 pool heater i have 2 100 lbs tanks
This is something your gas company should figure and supply for libality reasons. they will be responseable for any damage done from improper pressure. They will need to figure along with heater size and tank size, pipe size and run of pipe along with other varebeles like number and type of fittings on line and other appliences on the feed.
Apr 30, 2010 | Hayward H-series Electronic Gas Pool...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Pool & Spa Logo
242 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
