Question about Briggs and Stratton 073001 2" Portable Gas Powered 5.5 HP Water Pump
Valve clearance what is the valve clearance for a briggs 14.5 ohv
  • 2,841 Answers
Posted on Apr 25, 2010
I have a bs ohv ,6 hp on mtd tiller, problems, govenor does not work, engine runs at highspeed all time, also the pull rope is very hard to pull and will not spin the ingine
Posted on May 22, 2011
Valve settings on 17hp briggs ohv engine
.004 to .006 i set them at .005 no problem run great start easy
Nov 15, 2016 | Garden
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
How tocheck timing onbriggs stratton model44577
The timing is fixed, if you suspect the timing is off the only adjustments available are the .030 clearance from pickup to flywheel and the shear Key that positions the flywheel on the crankshaft. You would also want to make sure your valve clearance is .030 as well, the issue sounds like a valve leaking, a dead cylinder or mal adjusted valve clearance causing the exhaust valve to hang open just a bit.
May 13, 2014 | Briggs & Stratton Briggs Stratton Intek V...
What is valve clearance on 16 hp ohv
Valve clearance on the ohv engine is .004 inches on all valves.
May 13, 2014 | Briggs & Stratton Garden
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Intake valve & exhause clearance
3000 or 4000 is your clearance, get the piston up top dead center make sure piston is to the top of the cylinder rocker arms should be level with each other before you set them
Jun 05, 2010 | Swisher T14560 T - 60" Trailmower with 14...
Briggs and Stratton 073001 2" Portable Gas Powered 5.5 HP Water Pump Logo
555 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
Mike Carew
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
