Question about Maytag MSD2454G Side by Side Refrigerator
Water leaking and freezing at bottom of freezer in side by side Maytag model # msd2454gr refridgerator.
  • 375 Answers
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
Maytag side be side model msd2454gr
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water drip at base of freezer door at bottom!
Have you had a chance to locate the location the water inside freezer? There are many reasons for this to happen I just can not say it would be a defrost condensate drain blockage. Most times it is. Every 8 to 10 hours your freezer defrost and the water is surposed to follow a pipe or drain through the refrigerator to a pan below refrigerator where the warm air from condenser evaporates the water back to the air inside your home. That drain line sometimes slowly becomes blocked and then the drain hole becomes clogged with ice. Once that happens the drain needs to be cleared. I will try to help you solve this so for now I need you to see if water looks as if it came from rear of freezer. Placing photos on Flickr would be great! So tell me where you see it and yes we may need to pull a few things out. This is nothing a few towels, hair dryer hot water and Clorox and a wet vacuum cannot handle. Sea Breeze
Mar 20, 2010 | Maytag MSD2454G Side by Side Refrigerator
WATER LEAKING OUT OF FREEZER DOOR
The defrost drain hole in the bottom of the freezer has frozen over. Turn off the fridge. Remove the shelves and bins. Remove the rear panel of the freezer. You will see ice on the bottom rear of the freezer. Use a hair dryer to melt the ice,especially in the drain hole once you get through the surface ice. Once the drain hole is clear,pour a cup of hot water through the drain hole followed by 1/4 cup bleach. Re-install your parts and turn the fridge back on.
Sep 21, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Maytag side by side
I have a Maytag side by side MSD2456D and water is running out bottom of freezer door onto floor. There is ice on the freezer coils and there is what looks like a drain tube with a plastic wrapping. I think water is leaking there and freezing on coils until it defrosts ice.Water then appears to run down inside of freezer and out bottom door seal.
Does any one have a suggestion on repair parts. How about owners/repair manual
May 31, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
830 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
