Time and date stop when laptop powered off.
Samung R20 Laptop initially had time ''racing '' forward. Time reset and changing internet synch clocks held time correct for about 4 minutes, then it started running at 30 -60 times to fast.
Updated Bios from Samsung, reset clocks and internet synch. Ran fine whilst powered up, but time stops when switched off.
I assume it is the cmos battery which has failed. Laptop is two years old. Never come across a cmos battery packing up in a laptop in over 10 years!
Does anybody know where the cmos battery is located and is my diagnosis correct please?
    Sergeant:
    Champion:
  • 305 Answers
It sounds like the cmos batt had the same problem with my desk top once changed cmos batt all was fine .the batt is located on the under side of the laptop you will see some removeable panels just check under these,but be carefull the batt might be soldered in, some are some are not. if soldered in you might want to get a professional to change it as the heat could damage your computer.
hope this helps.
Posted on Apr 29, 2010
My D 630 Win 7 laptop periodically resets time & date to the last manual setting? Is there a fix?
Not too difficult if your a member of the computer Dr mobile pc Dr's in black n white volkswagons. But it is the battery on the mother board
it should be 3.0 volt lithium watch battery 2016. Battery is dying an not holding its tsr programs on the cpu an reseting to defualt cmos
changing battery's information onyoutube based on your pc cabinet and its model and serial number. They'll play start to finish end user information on issues listed by steps
Aug 26, 2014 | Dell Computers & Internet
How to fix Time-of-day clock stopped
Is it actually stopped or does it return to a default time when the laptop is unplugged for a while?
I assume you have already reset the clock, it's located in control panel under Date & Time. You can also set the clock in the BIOS.
If the time does not advance at all, your motherboard will have to be replaced as the clock chip is not replaceable.
If the clock just needs to be reset every time you use the laptop, you might try leaving it plugged in overnight to recharge the clock battery. If that doesn't help, the clock battery is bad.
Aug 21, 2014 | Dell Latitude E6400 Laptop
Setting clock on laptop toshiba need to find out how to change time on laptop pc
Click on the clock time and you can edit the time and date.
The clock time is on the bottom right hand side of the desktop.
Feb 07, 2014 | Toshiba Computers & Internet
How to set timeron vaillant
If I understand your question, you want to set the time on a laptop. Go to the computers clock located in the taskbar notication area in the right bottom corner of the desktop, right click the clock, click on adjust date and time, open date and time, at the top click on the Internet Time tab, click on change settings,open Internet Time settings, click update now. If you are connected to the internet it will set automaticly, if not, go to control panel, look for date and time.
Nov 07, 2012 | KDS Valiant 6380iPTD-01 Notebook
Hi How to check Reset signal and clock signal on Laptop mother board Please help
control panel date and time,date&time,time zone,internet time hope this helps
Oct 05, 2010 | HP Compaq Presario V5000 V5100 V5200 V5300...
Bios clock has stopped on Fujitsu T4215 tablet pc. Have tried: 1) updating bios 2) re-installing cmos clock Clock starts again once in Windows (but from static date in bios) and can synchronize clock from...
I thik your CMOS clock (HH:MM:SS ) SS digit not moving forward. If it is then just unplug your CMOS Battery and 5 min later reassemble it ...your problem will be solved.if your BIOS whole setup reset including clock and SSS digit moving forward then replace your CMOS battery...if your not expert to open laptop then take a expart help to open it and run this procedure..
May 14, 2010 | Fujitsu LifeBook T4215 Tablet PC
Thinkpad R40 find date & time for start-up
Right-click the time in the lower right, select: adjust date and time, select: internet time, select either source, select: apply (if high lighted)--otherwise close. You need to be connected to the internet for the internet time to work.
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Inspiron laptop clock incorrect
Go into the BIOS by turning on the laptop and pressing F2. In there i believe on the main screen you can change the time and date. Do that, save changes and exit and then go into windows and see if it keeps the right time and date.
Let me know how it goes.
May 12, 2009 | Dell Inspiron 1525 Laptop
I do not know how to set my clock on my razr after the time change last nite
Settings
Initial Setup
Time and date
  • Turn AutoUpdate Off
select and make the change
Nov 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
