Question about Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher
Kenmore thermal fuse keeps blowing and im getting a white powdery film
    President:
  • 949 Answers
If the thermal fuse blows it is a direct result of heat. The most common place for the heat to be generated is the wire connections to the fuse, the wire connections on the main control board and the door switch.
The thermal fuse comes with a small wire kit, be sure you or the technician used that wire kit if not you will continue to have trouble. If you have then look the board over closely, especially the black plastic plugs, if you see any dark spots or loose connections make sure to tighten them up. Then check the wires to the door switches make sure they are tight connections. If all these are okay then check the gasket on the left side that surrounds the vent, if heat escapes this gasket it can migrate over toward that thermal fuse.
I hope this helps
Posted on Apr 25, 2010
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Thermal fuse blown on kenmore dryer what is the cause
The thermal fuse blows when the vent gets restricted and builds up too much heat. After it gets to a certain point the thermal fuse blows. Clean out the vent, keep the lint trap clean, and hopefully your problems will go away.
Feb 04, 2012 | Dryers
All of a sudden my dishwasher is leaving a white powdery film on the dishes and really bad on the utensils. It had been working beautifully. Is there something inside that might be clogged that I should...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My kenmore 70 dryer quit heating but runs like it should, does it have fuses inside the dryer? we have a breaker bos and breaker not tripped.
Thermal Fuse is located inside the dryer, If the thermal fuse gets too hot, it will blow, and completely shut down your dryer until it is replaced. This fuse is often mounted within the exhaust duct in the back panel. It’s about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced. When replacing this fuse, check the dryer vents to make sure there is no lint buildup which can cause the heat to stay trapped and blow the fuse again.
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 01, 2010 | Kenmore Dryers
I have a white powder residue on my dishes after a cycle. I do not have hard water and am not using too much detergent. I am doing the same thing I've always done, only now all of a sudden I'm getting...
heatman101
Jun 20, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
Where are fuses located on kenmore dryer part#3394996 one of the connecters on heating element sparked and im thinking it blowed a fuse
Dryers have a thermal fuse... it's a ceramic 2-3 inch long resin-filled fuse with wires attached at both ends... near the motor...inside the dryer..
The other fuse would be your house circuit breaker panel. Check the thermal fuse..
Dec 08, 2009 | Kenmore Dryers
No heat...replaced vent hose...still no heat. Model 110 72922100 Sears Kenmore 90 Series. Please advise.
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help.
Jul 12, 2009 | Kenmore Dryers
I need to put in hi-limit thermal fuse how .show
Hello Friend, This problem will be an easy quick fix for you. All you need is a thermal fuse, your cost under $20. Remove back cover from dryer, look down towards where the air blows out, then just to the left where all the wires are. You will see a little white plastic part with two wires plugged into it, this part is called a thermal fuse. Just unplug these wires and replace the thermal fuse. This should solve your problem. Happy to help, Tim.
Jun 23, 2009 | Kenmore Dryers
Kenmore electric dryer (model # 110 60202990) dried a load of clothes like normal. But with the current load, it suddenly stopped heating. How can I fix this?
Jun 12, 2009 | Kenmore 64742 Electric Dryer
Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher Logo
394 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
