Question about Alpine CDA-9884 Car CD/ MP3 Player
We are getting very little sound from our mids and our subs when hooked up our making a making a sound like our ground is screwed only when we installed our alpine we tried our jvc again and sound is fine
  • s_ssenay Apr 25, 2010
    i know our speakers amp and subs our fine this is not the problem
  • 2,005 Answers
Check to see if your alpine needs an external crossover and, your jvc doesn't.
Posted on Apr 25, 2010
  • 22,326 Answers
Without having a play and a swear at it,this sort of problem is difficult to advise without a hands on but providing you have the speaker wires correctly connected then i would hazard a guess and say the output transistors are either weak or just been overloaded and cooked
No sound from speakers, but yes from sub. Grounding issue?
Grounding issues are just simply earth connections that are either loose or are badly soldered. Sometimes with bad soldering a knock on the unit can make it play. It's just a question of going inside and looking - with a lens sometimes - at soldering joints - wire connections and screws fixing. Random cut outs certainly sound like bad soldering problems etc. The only other cause is heat sensitive devices, which shut down when too hot. But I wouldn't jump to that conclusion just yet.
Apr 14, 2015 | Samsung HW-C500
Why does my sub have low sound with my sound bar?
Your sub will only produce lows. You cannot hook up a sub and expect to get mids or highs if that is what you are looking for.
Aug 30, 2014 | LG Lsb316 Sound Bar With Wireless...
I tried hooing up my amp and subs but i get
make sure u have
power source with inline fuse working.
a ground line getting a good ground(scratch paint off care frame screw it down).
remote line from amp connected to the remote line on the radio.
and make sure you have rca running to the sub input on your radio.
and your speakers are connected.
Mar 25, 2010 | Kenwood KDC-138 FM / AM Receiver
Amp is pulsating the subs uncontrolably, maybe its not hooked up right? its a kicker kx800.2 with a cap ooked up to 2 12 mtx audio subs....any ideas?
Hey make sure your ground is good. i had a problem like this befor and it was when i hooked the rca's in it would be pumping out bassing staticy noise and i had no acual ground hooked up took the screw and moved it to scratch the paint and Boom the real Bass came in. ....i thought it was grounded but it was not.
Jan 10, 2010 | Kicker KX800.2 Car Audio Amplifier
Amplifier and sub installation in a boat.
norally grounding them in the same place is ok but it could just theres not enough power from the amp too power two subs try hooking up one and see if that gives you the sound your looking for
Jul 09, 2009 | Car Audio & Video
Pulsating subs
sound like weak ground maybe try different location or larger wire
May 05, 2009 | Car Audio & Video
High wattage car stereo
positive (1 guage) from main battery to second battery positive terminal. hook all amps positive to second battery and hook 2nd battery ground to frame of car (where amp is now grounded) if you have a 2nd battery a cap is a waste of money. make sure all grounds (battery and amps) are together on same ground point of car, do not ground amps to battery - ground everything to 1 spot on the frame or body of the car ! - yes you can pigtail remote leads.
Jan 01, 2009 | Kicker KX650.4 Car Audio Amplifier
Is it a good idea
Based on your description and on the idea of a single amp, then your plan of hooking up both the subwoofers in series (to get 8 ohms) would be the safest as against running the subs in parallel (2 ohms). This way the sub amp would not be overly loaded, you can compensate the slight loss in power by strategically positioning the 2 subs. A friendly reminder, pls observe polarity when hooking the sub speakers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Car Audio & Video
Sony Xplod 500w green power light no sound
try running the system with a cross-over configuration.
So your left + will be left + and your right + will be in the right + but put the right (-) where the left (-) is and left (-) where the right (-) is. If that doesnt work, then that means that you shorted out your audio out channels. the only way you can fix that is if you have good soldering skills. But other than that I'de say scrap it, unless you have the high outputs and then buy another amp, some mids and highs and connect the mids and highs to the xplod
Feb 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Off and On at mid and high volumes
sounds like you have a problem with your grounding on you amplifier. check for shorts on your amplifier and the place where you have it grounded. (or check the power wire also.)
Nov 01, 2006 | Kenwood KAC-7202 Car Audio Amplifier
Alpine CDA-9884 Car CD/ MP3 Player Logo
46 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
