Question about Frigidaire Electric Dryer
My dryer SHOWS ERROR 68 ON PANEL and shuts off?
DRYER SHUTS OFF AND STATES ERROR 68
Error 68 can mean that your start button is stuck; check to make sure the button is not stuck in the pressed position behind the controls cover.
Posted on May 05, 2010
THIS IS THE SOLUTION EVERYBODY HAS BEEN ASKING FOR AND I FINALLY FOUND IT, TRIED IT, AND IT WORKED.
Remove the lint filer. Now remove the waffled plastic that covers the lint filter slot. The screws are inside the dryer, so you can't see them unless you put your head into drum.Unscrew the 2 screws and don't let them fall into lint filter slot. Be careful when pulling off this piece as it is attached by 2 wires. These connectors may be temp or moisture sensors, but mine were covered in lint. I cleaned the inside of the lint filter area with slim nozzle vacuum and them carefully dusted off the wires (small paint brush). . Put everything back to gether... and Ta da! *E68 error is Gone . Barb1948
Posted on Nov 01, 2012
I have a Frigidaire dryer that the timer will not shut off. dryer works but gives error 68 on disdplay. what does that mean
stuck button. Test: Move knob to normal hold down a couple buttons then a few more then you do the hokey pokey. Check out Bill's video:
Jan 07, 2017 | Frigidaire Dryers
What is an error code e-68 on a galaxy series dryer mean
E68 error code is a stuck button error code. You can try to wiggle each button on the control panel to make sure they are all functioning freely. If so, then unplug the dryer and leave it unplugged a couple minutes then plug the dryer back in to clear the electronic panel's error code. If the panel still shoes E68, then you'll need to replace the panel. Part#134557201
Hope this helps!!
Jun 13, 2016 | Dryers
Frigidaire affinity dryer error 68 and hot to touch
Hey friend, thank you for allowing me to assist you!
I understand that you are getting an E68 error code on your Frigidaire Affinity dryer, it usually stands for a key (button) that is stuck closed (active). Let's try entering a "Function Test Mode" and perform the Key Test to determine which button could be the problem. To perform "Function Test Mode": Press and hold START and the CANCEL button at the same time for 10 seconds. The key that is stuck should blink. Free the key and perform the test again. If the button is free but the error code still exists, the electronic control will more than likely need to be replaced after it has been properly diagnosed by a professional. If you need help in contacting a technician you can view the manufacturer website to find available technicians in your area. Hope this is helpful. -Matt
Jul 26, 2014 | Dryers
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
Frigidaire dryer code e4a
Good Afternoon Friend,
I understand that you are receiving an E4A error code on your Frigidaire dryer. I do not show an E4A error code for your appliance. I do have an EA4 error code which states improper home wiring. The other possibility is that this could be a false error code. I suggest resetting your dryer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your dryer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Dryers
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 | Dryers
My electric dryer tell me ERROR 68 on the screen ¡¡ Plus every 5 minuts stop for she self ¡
The data sheet says "One of the buttons is stuck closed". If you can't solve this by inspecting & jiggling the buttons, open the lower front panel of the machine, & look behind it for the "Tech Data Sheet*. Follow the instructions for error 68.
Nov 27, 2009 | Frigidaire FEQ1442ES Electric Dryer
ERROR CODE 68 WILL NOT CANCEL. IF YOU PRESS CANCEL AND THEN START IT RUNS FOR ABOUT A MINUTE AND STOPS
code 68 [aeq7000es series]relates to "stuck buttons, or control panel issues. Try to see if your dryer will give you the code for which button is stuck and try to wiggle it to free it up if stuck. If all buttons check out good then you most likely have a bad control panel ,and its time to find your best deal on one
Sep 29, 2009 | Frigidaire AEQ7000ES Dryer
Fridgidaire Error 68 (model No. LE02152EEO) and constant beeping!
this fault code means there is a stuck key on the control board.you need to disassemble the display panel and free up the stuck key if this does not work then the display panel and or control board need to be replaced
Sep 02, 2009 | Frigidaire AEQ6000ES Electric Dryer
Error e 68 pops up and dryer turns off. Doe sthis
Hi
Thanks for using FixYa. E 68 error means that there is a leakage of current to the ground on heater or fuse opened. Also check the resistance of the NTC which should be around 50K ohms. If not then you need to replace the water inlet valve assembly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | Frigidaire Dryers
Frigidaire  Electric Dryer Logo
656 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
