Question about Cameras
Kodak I733 LP Digital Camera won't turn on and lens is stuck in out position.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 25, 2010
Kodak m1063 lens stuck closed won't open
I suggest you take your camera to a digital/Kodak camera repairer.
Apr 18, 2013 | Kodak EasyShare V1003 Digital Camera
Kodak easyshare c1530 won't turn on after slighty dropped
Hello Doris, You can "GENTLY" try to push the lens slowly back into the camera with the palm of your hand, note I said gently and slowly, do not use force !!! Then turn on camera and see if this helped, if not it is repair time.
Jan 26, 2013 | Kodak C1530 Digital Camera
Camera won't stay on making funny noise lens won'tpop out
your lens is stuck up,making camera hesitate to turn on. may be dirt sticked on it. have it cleaned carefully and retry. regards
Sep 30, 2011 | Kodak EasyShare Z650 Digital Camera
Polaroid i733 digital camera lens stuck open
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the
batteries. (obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
May 15, 2010 | Polaroid i733LP Digital Camera
Zoom Lens stuck out, won,t close. Says camera problem #E45
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Nov 12, 2009 | Kodak EasyShare V530 Digital Camera
It won't stay powered up
Hi!
Either the lens stucks in outter position or the focus is stuck. It's hard to tell without seeing it and taking apart the camera and lens. You should give it to a local repair shop or Kodak service center.
I work in Kodak service center.
Tom
Sep 26, 2009 | Kodak EasyShare M1033 - black Digital...
My polaroid i733 turns on the beeps 3 times then turns off when the sd card is in. i have tried formatting the card and camera but it still is not working any help
Had the same problem with our i733 Pink Polaroid. Beeps three times and then shuts off. The reason for this is that the lens is stuck in the partially open position. Because our camera was long past warranty and we bought it for $40 second hand I took the brute force approach. I grabbed hold of the lens and wiggled it from side to side while trying to pull it out (forcefully but being as careful as I could not to damage it) and then there was a small "pop" and the lens came out all the way and the camera was good to go again. Hope this helps.
Jul 25, 2009 | Polaroid i733LP Digital Camera
KODAK M863 LENS STUCK
Here's what I did...Mine had the lens stuck out and would not power on. Just a green blinking for a second or two. Well, I tried twisting the lens ring closest to the camera while hitting the power button. It's kinda tricky to do...BUT, just keep at it. Mine was a $1 resale shop "find" and now it works. This worked for me. Maybe it will help you!
Apr 18, 2009 | Kodak EasyShare M863 Digital Camera
Lens stuck camera turing on and off
Lens mechanism is shot. A repairs is not likely to be an economic proposition Contact Kodak customer support for a try
Jul 29, 2007 | Kodak EasyShare Z710 Digital Camera
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
