Question about Dell Inspiron E1505 Notebook
My dell e1505 will only urn on for a few seconds then shut down. It also has a black screen even when it's on. Any advice is appreciated. Thanks!
    Novelist:
  • 128 Answers
These are the steps that you need to take, and the instructions on how to do it:
1. Reboot into Safemode
2. Run a virus and spyware scanner
3. Defrag
4. Scandisk
5. Registry error repairing
6.Reboot into regular mode windows
Here is how to do it:
Reboot yor machine while holding the F8 key right as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is definitely a hardware problem.
PRINT THESE INSTRUCTIONS AND KEEP A COPY NEAR YOUR SYSTEM FOR FUTURE PROBLEMS. THIS SERIES OF STEPS CAN FIX MANY PROBLEMS
If the above doesn't work, replace the battery.
Good luck.
James.
------PLEASE RATE THIS ADVICE WITH 4 THUMBS UP!!!-----
Posted on Apr 25, 2010
Dell e1505 won't power off
Check or Change the PSU or charger.
Jun 28, 2012 | Computers & Internet
My e1505 on startup flashes on the a and down arrow indicators on the lock looking thing to the left of the power button. It flashes for about 30 seconds and then shuts off. I can't even get the thing to...
Most likely, this indicator shows motherboard issue. A motherboard replacement must be needed for it to work. Since its not even posting nor even showing BIOS, that is the last thing you can do.
May 21, 2010 | Computers & Internet
When i close the lid on my dell inspiron E1505 the screen goes black and when i open it back up it stays black
The cable for the back light inverter board may have come off on the mother board side or on the screen side.
2) Failed inverter board.
3) Failed lamp.
Apr 02, 2010 | Dell Inspiron E1505 Notebook
Dell E1505 Intermittent display loss CPU: Intel core duo T5300 2.0ghz RAM: 2gig PC2-4200 ram (Hynix is the brand i think?) VID: ATI X1400 256mb HDD: 80gb 5400rpm hd OS: Windows Media Center w/ SP3 and...
You might be able to verify by taking a fairly bright flashlight and aiminig across your screen when it does shut off. If you can see the image, it's probably the inverter.
If you've tried an external monitor and it does the same thing, it's probably the video card (hopefully yours is the replaceable kind.)
Six screws on the bezel and carefully pop it off. The inverter is on the bottom of the screen. I just replaced a broken screen on that exact model.
Jan 08, 2010 | Dell Inspiron E1505 Notebook
Inspiron e1505
You should be able to restore the system from the recovery partition on that model laptop.
Shut down the system. Then start it up. Right after pushing the power button to start it, hold down the CTRL and keep tapping the F11 key(for XP). If you have Vista just tap on F8(no need to hold down CTRL). A symantec recovery application (PC Restore) window will start up. just follow the instructions on the window.
Regards.
Sep 14, 2009 | Computers & Internet
Screen goes black with power cord pluged in...
Did you check your power management settings?
Have you tried cycling through the monitor modes (Fn +F8)? THere are three modes. If you're on the presentation mode, video is being sent only to an external monitor, not your laptop screen.
Jun 06, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Blank screen when powered on.
Do you have any CD’s that came with your laptop? If so, look for one that has “Diagnostics and utilities” listed under the “Contents”. To boot from that CD disk, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. You can also boot from the Windows reinstallation disk. If the computer boots from either CD, then your Operating System is corrupted and needs to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Inspiron E1505 Notebook
Does not power up
Battery may be bad on the laptop. Try removing the battery and powering on the computer with only the AC power.
(Usually you can flip them over and there's a locking "slide" that you have to hold over while you remove the battery. )
If it still refuses to power it on, try to note what it says on the screen (use a digital camera to snap a few photos if necessary) and post back. It seems likely that it's the battery, however.
Hope that helps.
Nov 30, 2008 | Dell Inspiron E1505 Notebook
Screen is black
When you say sounds like it starting up, can you hear the Windows sound byte, or just the hard drive spinning and CD drive engaging?
Aug 12, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
100 people viewed this question
Alun Cox
