Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Boss 4870gz shuts off (thermal protector) after 2 or 3 min
I have checked for any plugged areas, changed the bag and have run the vac without the filter and it still shuts off. Is it possible that the motor is bad or that the thermistat needs repaced or ??????
    Problem Solver:
  • 5 Answers
Wiggle the cord while running the vac. if it cuts off from that, then you most likely have a bad switch or cord. if the motor was bad, you would smell it. it smells aweful.
Posted on Apr 26, 2010
Where is the reset button the eureka the boss smart vac
There are many different models of Boss Smart vac so I can't say for sure without your model number but it most likely does not have a reset button. It may have a reset switch built into the motor.
Feb 26, 2017 | Eureka Vacuums
Lately as I'm vacuuming, my vacuum will turn off. I can start it again, and it will shut off again. It seems like a power issue. Happens different places in the home, so it is not the outlet.
Some vacs shut off when the dirt bag is full Check your brush area and see if there is dirt or bits of string like things wrapped around the brush or the brush ends. This will cause the machine to shut down as well if there is pressure holding the brushes. Will it run if you wiggle the plug if so you could have a bad plug as well.
Jul 07, 2015 | Kenmore Vacuums
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuum squeals when running. Big boss smart vac 4870
most likely you have something trap in the blower fan. if not chech for some obtruction in the tube. a piece of paper or the like. also check you belt.
Feb 06, 2011 | Eureka Smartvac 4870 Bagged Upright Vacuum
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
Bag model for Eureka Mega Boss 4460 type E
The model 4460 is for a Victory model which uses Eureka Type AA bags
They can be found at http://www.totalvac.com/eureka_aa_bags.html
Jun 10, 2010 | Eureka Mega Boss 4460DT Vacuum
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have the eureka boss smart vac upright and was cleaning a very dirty room and the power went off...the bag was full ...is this common or a big problem
Could be a automatic shut off to avoid damage..
Change the bag and be sure there is no clogs..
Have a great day !
Oct 26, 2009 | Eureka Vacuums
Something is stuck in my hose on the eureka boss smartvac, can i dtach plastic hose on side
yes, there are a few screws that need to come out to do so, u can also use a coat hanger to loosen it up and turn it on, the vac will **** the loose dirt into the bag/canister
Jul 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
532 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
