Question about Sony XM-2002GTW Car Amp
I have 2 dual 2-ohms solobaric speakers and im trying to put them on my sony xm-2002gtw amp.im trying to get the max 1200 watts,whats the correct way to hook these speakers up.
  • 344 Answers
I have two sony xplod 12" speakers wich can hold
You only gave us the model of the amp so I will make an assumption that your 12" subs are the Sony XS-GTX120LW. First, they cannot hold 1200 watts a piece. They are meant to be powered with 350 watts RMS. They will hold 1200 watts peak. That means that 1200 watts for a few seconds will be ok. Past that and kiss them goodbye!
Next you indicated that bridged the amp. Since the subs are both 4 ohm single voice coils did you wire them in series or parallel?
It sounds to me like you wired them in parallel resulting in the amp seeing a 2 ohm load. The amp you referenced is only stable when bridged at 4 ohms.
Has the amp begun working again once it cooled down? If not you could have fried the outputs by having the resistance too low.
Dec 21, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
XM-2002GTW Car Amp: i have 2 dual 2-ohms solobaric speakers and im try...
I researched your amp and it looks like its not even 2 ohm stable :( the problem with these companies is they lable there amps 1200 watts MAX, that means they tested the amp in a perfect enviroment and the amp fried somewhere in the ball park of 1200 watts, your best bet is to save your money and buy a nicer amp that is two or one ohm stable... that being said the best way to wire your subs is in series
May 17, 2010 | Sony XM-2002GTW Car Amp
I have a sony xm-2002gtw amp and i want to bridge this amp to get the full 1200-watts,how would i wire my speakers i have two 2-ohm dual solo baric
In order to get full power from the amp you need to wire you amp ( high level input of the amp ) to your cars rear speakers both left and right ( negative to negative positive to positive ), once done you can wire your speaker to the left and right speaker output of the amp. Comment if you need more assistance. Best of luck
Feb 15, 2010 | Sony XM-2002GTW Car Amp
I have a sony xm-2002gtw and i want to know if i can hook two 2-ohm dual subwoofers up to this amp and how i have 2 solo baric 12-inch.
200W x 2 @ 4 Ohm
500W x 1 @ 4 Ohm
This amplifier cannot handle a load lower than 4 Ohms in stereo or bridged mode.
If the subs are Dual 2 ohm - You cannot wire a 4 ohm load with (2) subwoofers.
Only 8, 2, or 1/2 ohm loads are possible with (2) dual 2ohm voicecoils
Thanks!
Feb 15, 2010 | Car Audio & Video
What wattage amp do I need to get good sound in a toyota corolla
Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have 1000 watt sony XPLOD amp and i just installed it today. with new monster cable&ground. the green light turns on& thumping goes for a little. i try to raise up just a little bit& after 2...
it isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
Jun 13, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
AMP shuts off
your problem could be in the fact that you are trying to overdrive the amp. sony will not carry a 1 ohm stable load and if your speaker are 4 ohm speakers wired in series then you cant drive the bass your looking for. try using soundstream tarantula amp or new hifonics block mono class d amp with about 1000 watts rms. what kicker subs do you have? that will also make the difference in amp choice. im running tarantula on 4 polk momo 4 ohm 12's and has broke my back glass in my jeep twice one time was for a show. oh well let me know. happy boom boom. i'll be glad to help
Feb 28, 2009 | Sony Car Audio & Video
Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
Feb 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony XM-2002GTW Car Amp Logo
61 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
