Question about Craftsman 20 Hp 42" Deck Lawn Tractor
My Craftsman Lawn Tractor 917 28726 will not stay running. Seems like it has a fuel flow problem
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 376 Answers
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
GM Elec
  • 1000 Answers
SOURCE: Need parts manual for Craftsman 22HP 50 inch deck lawn tractor
Go to "sears.com", have your model number ready and go to the parts link. You will beable to view an exploded view of your mower and order parts on line if you like.
Hope this fixes your question, let me know.
Regards,
Posted on Jun 12, 2009
Craftsman lawn tractor mod:917274660. gas not reaching fuel pump. how do I fix? installed new pump. still doesn't work
unhook the fuel line at the fuel pump and see if fuel will flow from the fuel tank. if not there may be a blockage in the tank or bad fuel lines.
Apr 22, 2017 | Craftsman Garden
Tractor
be careful with starting fluids, they strip cylinder walls, NOT a good thing. Prime with WD 40 or gasoline. forget the starter fluids. In all likely hood your carb needs cleaning. Pull the fuel line off the carb first though, and crank the engine. If you get good fuel flow, you just have a plugged fuel filter.
Jul 05, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor backfiring
clean the jets inside the carb
Aug 06, 2012 | Craftsman Garden
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Starts quits then starts after a few min
Have you checked your fuel filter? it may be clogged or contain water, which will limit flow of the fuel. This would be simplest to relace. Otherwise I believe it to be a carb problem.
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
246 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
