Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
What is the ignition module gao for tb575ss - Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Do you mix the gas and oil together with the Troy-Bilt4 cycle TB575SS. Lost directions. Thank you
No. You do that for a 2-stroke engine. Your engine should have oil in the crankcase and you just need to check the level of it and add gas to it like a regular lawnmower engine.
Sep 06, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Have a troy built TB575SS trimer. Pull cord has lost tension and cord is just fully hanging out. How do I I take unit apart to re-adjust cord tension?
The starter recoil spring may have possibly broke or the rope is hung up somewhere on or in the pulley. A lot of these units are assembled using Torx (Star) head screws and disassembly requires a couple different sizes to accomplish. Take your time...you will see the screw heads, but reloading a starter spring for a trimmer is a little tricky and you may need help doing so, but you can fix this yourself.
May 29, 2010 | Troy Garden
Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
May 20, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to remove(unscrew?) centrifugal clutch assembly from engine shaft of TB575SS troybilt 4-cycle weed trimmer?
Remove spark plug and insert some cord into the spark plug hole to freeze the crank shaft. This way you can unscrew the clutch from the engine .
Jun 23, 2009 | Garden
My problem is a technicl support
what is your problem with the typewriter?
Apr 16, 2009 | IBM Wheelwriter 30 Typewriter
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
78 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
