Question about Caterpillar Cat Pump Pressure Washer Pump 2.5 Gpm, 2750 Psi, 5 Hp To 6.5 Hp Required, ModelNo. 3DX25GSI
Cat pump pressure washer 3DX25GSI -- No pressure, please help.
Oil leaking from where stainless steel meets aluminum body, what is the part packet I need to get. Ordered
it's an oil seal total of 3 possibly a 20x30x7,carfully pry the seal to see it's number you can get these seals from a store that sells bearings and shaft like miller bearing or go to pressure washer website and input the cat model #,hope this helped
Mar 16, 2013 | Cat Pump 3CP1231 - Stainless Steel Plunger...
I need to know to know how many psi model 2sfx30gz1 is. please.
The Cat 2SFX30GZ1 has the following specs:
3.0 GPM2500 PSI3450 RPM
We are a Cat dealer and have all breakdowns and parts available for this pump. If you have any questions please feel free to contact me using the information below.
Sincerely,Aron KerrLanda Northwest, Inc.www.landanw.comaron.kerr@landanw.com800.247.8103
Apr 14, 2012 | Caterpillar Cat Pump Pressure Washer Pump...
Cat pressure washer pump model 4hp40g1 no pressure and then quits, what could be wrong?
Sounds like you may need to remove the valves to check for any dirt etc. Is the machine juddering when on pressure. If so then it will be the valves that just want removing and cleaning
Jun 13, 2010 | Caterpillar Cat Pump Pressure Washer Pump...
Ex-Cell EXPRO2530 w/Cat Pump. Pressure builds and stalls engine.
Your unloader valve is not wotking, get a diagram of the pump from cat and it will show what parts you need to replace, or check for blockage in the valve.
May 23, 2010 | Caterpillar Cat Pump Pressure Washer Pump...
Low pressure
hi some valves at cat pumps need a 100 psi pressure to open and close correct. when there is air in the pump the valves wil not open and close till air is bleeded. take of highpressure hose, open watertap and bleed pump till no more air comes out. reconnect all hoses and try again. if there is no more air in the pump and its still not working, i should think its the pump.
Jan 31, 2010 | Dewalt 3800 PSI Pressure Washer
I have excell 3700 pressure washer...the pump cover vibrated loose lost oil and cam melted.how do i get parts and change pum cam?
When you get down to it, purchacing oil end parts for a pressure washer is not cost effective.
The crank(cam) shaft runs about 280.00 dollars. The oil seals, new bearings, possibly new pistons and almost definatly new seals would be at least a hundred more. You can get a new pump for about 400 dollars and won't have to do all the work.
Dec 18, 2009 | Psi PowerBoss 20262 Pressure Washer
What type of oil does the pump use? how much?
8.5 oz. to the red dot on the site glass.
SAE 30 / 30 wt Non Detergent Oil from your local auto parts house.
Oct 02, 2009 | Caterpillar Cat Pump Pressure Washer Pump...
Oil used for Cat Pump on pressure washer?
It will be a 30 wt non detergent oil probably. You could contact a Rental store in your area they will have what you need. Hope this helps. 2rns4u <*{{{>(
Jul 22, 2009 | Honda Pressure Washer PSI 3000
Caterpillar Cat Pump Pressure Washer Pump 2.5 Gpm, 2750 Psi, 5 Hp To 6.5 Hp Required, ModelNo. 3DX25GSI Logo
319 people viewed this question
Top Caterpillar Garden Experts
J.D. Browning
J.D. Browning
downhille
Bill Boyd
Are you a Caterpillar Garden Expert? Answer questions, earn points and help others
