Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Not able to start dishwasher
The clean button keeps blinking green. Not able to start dishwasher or cancel previous cycle.
    President:
  • 949 Answers
Here is a quick check list to do and the instructions to reset the control so you can use it again, if you have trouble with the same blinking let me know and we can dig deeper to fix it.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on Apr 25, 2010
Our Whirlpool dishwasher GU2500XTPT1 clean light blinks and will not go off. When we push the start/cancel button, it cycles through the 2 min cycle as the book says it should do and all lights go off. ...
That could be a problem with the control board, but before anything else try unplugging it from the wall, or turning the circuit breaker off. After turning it back on, see if it still happens. Also check to be sure the door is closing properly.
Oct 06, 2017 | Whirlpool 24" Bisque BuiltIn Dishwasher...
My dishwasher blinks the green clean light
May have a bad heater. press hi temp, air dry,hi temp, air dry (or whatever button is equivalent on your model). this starts a test and will allow unit to work again. When drying light goes out touch the heater. If it is cold then it may be bad. You will need a voltmeter to tell for sure however.
May 27, 2010 | Whirlpool 24 in. GU2548XTP Built-in...
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
90 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
