Question about HP Computers & Internet
HP NOTEBOOK WON'T BOOT AND MAKING CLICKING SOUNDS
    Novelist:
  • 128 Answers
Your hard drive has failed. It is easy to remove and replace for about $100. Seek a tech if you are unsure how to do it. It is very simple.
Good luck,
James.
----Please click on 4 thumbs up 4 me!!!----
Posted on Apr 25, 2010
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem it won't boot up, it lights up but nothing else
Does it make a beeping sound when you turn it on? If it does try this:
Turn it off and take the battery out for about 2 minutes. Put the battery back in and press the power button to turn on. Immediately tap the F8 key on your keyboard. This will bring you to the advanced boot options. Choose last known good configuration.
If that doesn't work you may also try choosing system restore in the advanced boot options and follow the instructions. Note that a system restore brings the computer setting back to a previous restore point.
I hope this helps.
Cheers,
Sep 04, 2011 | HP Pavilion dv9000z Notebook
WON'T LET ME LOG ON WITH PASSWORD THAT USED TO WORK NOW IT WON;T LET ME LOG IN
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jun 24, 2011 | HP Pavilion dv6000z Notebook
HP NOTEBOOK WON'T BOOT UP...JUST CLICKING SOUND AND NON SYSTEM DISC ERROR
These are typical symptoms that your notebook's hard disk drive has failed. The drive will need to be replaced. Data recovery might be necessary for any valuable data that were on the older notebook.
Apr 25, 2010 | HP Computers & Internet
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
My system won`t come up after hibernation
go to the link
http://www.hp.com/#Support and select download drivers and softwares...in step 2 type in you products model number and click go now select your operating system.now in
the following window look for BIOS and
under BIOS click on Winflash for HP
notebooks.now in the following window
click on sp45070.exe and after that you
will get a box here click on run.now just
follow the onscreen wizard and click on
options like next and continue.once the
process is complete your system will
automatically shut down.just turn on the
system and it should work fine after
that.
Jan 21, 2010 | HP Pavilion Tablet Notebook
Bootsafe error on hp compaq notebook notebook pc while booting
Boot from the XP disc and press R at the first screen. This takes you into Recovery Console. Run these commands:
fixboot c:
fixmbr
exit
The computer will restart and hopefully it will load Windows.
If not, is your computer making clicking sounds?
Jan 25, 2009 | HP Compaq Presario SR1920NX PC Desktop
Hp pavilion dv9000 blue lights on won`t boot stuck just cli
Sounds like the harddrive went bad.
Some people call it the click of death.
Put the laptop to your ear near the harddrive and you will hear the clicking coming from there.
Good news is that it's easy enough to change the harddrive.
Bad news is you lose all your data to this point.
I hope this helps and i'm sorry that happend to you.
Dec 24, 2008 | Acer Aspire 5315 Notebook
Drivers missing
www1.hp.com/wwpc/uk/en/sm/WF05a/5043-5343-5347-5347-5427-7414095.html - 43k -
Nov 01, 2008 | HP Compaq nc6000 Notebook
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
107 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
