Question about Dishwashers
The machine is not taking water to start it sounds as tho the pump is operating but wont fill
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will give you some things to check out to solve your problem...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Apr 27, 2010
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Washer not filling with water
sounds like a defective pressure switch that is just a spdt pressure operated switch and its stuck on the timer side of this switch and can't switch back to the fill side of the switch to fill the machine first before starting agitation,check voltage from the water fill wire off this switch for line voltage,then check from the wire on this switch to the timer for line voltage,probably no voltage from the water fill valve wire so it can't fill
Feb 21, 2013 | Kenmore Washing Machines
MACHINE WONT FILL WITH WATERAND THE WATERCHECH LIGHTS UP
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left. Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Feb 20, 2013 | Bosch Dishwashers
Machine wont drain
sounds like water pump is not operational or clogged
Nov 28, 2011 | Kenmore Washing Machines
My ignis washing machine stops in the middle of the washing cycle and makes a sound, kind of blowing.
there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses.
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. This advice was originally written when most washing machines were hot and cold fill and didn't have error codes. It's now been updated to reflect the fact that these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
If your washing machine is stuck full of water the water needs to be drained out and this article gives tips on how to do this. If the entire washing machine has gone dead leaving the machine full of water it may be worth checking that it isn't something as simple as a blown fuse ( Washing machine is dead, wont start ) in which case if you get the washer going again it should pump the water out itself.
If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes (in the most likely order) are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running.
Blockages are the more likely explanation, but pumps can fail.
Dec 31, 2010 | Amana NAV2330AW Top Load Washer
My Kenmore top load washing machine is stuck in
sounds like ur pump has gone out totally and the controller is bad cause its not filling the tub or is it if it is and just wont pump it out u have a bad pump
Feb 25, 2010 | Dryers
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
How to mend it .com - Bosch dishwasher SGS43A12GB-27 does not stop filling
possibly the inlet water valve stuck open tho this is rare.
disconnect the valve electrically and see if the fault is still present. if so, the valve is stuck open and needs replacing
Jun 24, 2008 | Bosch Dishwashers
Whirlpool AWM 6100 wont let in water?
this may sound silly but is the hot and cold hoses around the right way
Feb 18, 2008 | Washing Machines
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
