Question about Samsung Televison & Video
Can't get screw out of lamp housing only one on the middle left
  • 8 more comments
  • ccatali Apr 25, 2010
    I know how to I have seen video after video I am down to the one screw in the lamp housing unit located in the middle on the left hand side, there is a swing around pull handle from the right to pull straight out but screw just continues screwing to the left and does not become any looser just stays the model is HL-S4288W Nov 2006 BP68-00532 B or 8
    HL-S4288W Nov 2006 Samsung Slim DLP BP58-00532 B or 8 screw on housing just turns and turns no movement? help
    not good enough i sent model no in to help
    I ordered my new housing and lamp for Samsung HLS4288W? how can that be not a good number? thanks
    Sorry need new glasses is a BP6800574B and HL-S4266W
    you are right it is BP 68 00574b and hls4266w the housing and bulb i rec'd is correct for a hls4266w
    can you still help me get left side screw out of housing? it seems to be stuck
    i still need help are you still there?
    I can't do a pic but the inside of the dlp tv has a drawing to release the housing unit and it has but one screw shown on left side in the middle,the drawing shows to unscrew the one screw and it comes totally out then to pull the housing out by handle should be super easy but the screw just turns and turns does not loosen up or come out. shows BP64-00547B with HL-S4266W does this help? thanks
    so you know i want to pull out housing unit with bulb still in place and replace it with another housing unit and bulb, the screw I am trying to loosen is on the left side of housing unit while in tv it just turns and turns does not loosen
    are we on same page I hope so, does this make sense what I am doing and what I am trying to do? I do not want to take lamp out of housing just housing and lamp out of tv to replace with another thanks Cat
  • ccatali Apr 26, 2010
    that is the exact screw that just turns CCW over and over and does not loosen what can I do to get the screw out? thanks
  • 10,594 Answers
What is model number of your Samsung tv to provide you helpful info about lamp replacement.
Thanks.
Posted on Apr 25, 2010
  • 5 more comments
  • Shahid Electronics
    Shahid Electronics Apr 25, 2010
    Model and lamp numbers are incomplete/ incorrect.
    Please provide video link that you are referring to.
    Thanks.
    I double checked model number HLS4288W and afraid, its incorrect. HLS4266W found correct model.
    Please let me know where did you order lamp and housing, any website link for that?
    Thanks.
    There are two screws that hold lamp housing tight, one is locating near pull handle and other is in cross direction corner.
    Can you post here a picture of that screw that is causing problem?
    Ah, I thought you are replacing bulb in lamp housing.
    So the old lamp is still inside tv and need to be pulled out, right?
    That screw wont came off, it will get loose enough and will turn freely, then pull old lamp with little force from lamp housing of tv because lamp connector is also tight with ballast connector inside lamp housing and need little force to detach.
    Yes, we are on same page, as I said, that screw is to keep tight lamp in tv lamp housing.
    Please put any other screws back on lamp assembly and just unscrew that is mentioned, that screw wont come out, give it few CCW turns to loose it then pull complete lamp from tv for further work.
    Below image might help you.
    Shahid Electronics Apr 26, 2010
    Hold lamp handle and pull it slowly while turning screw. In my opinion, screw got free in its place and requires up lift to get it out from its place.
    Thanks.
I need instructions on how to replace the lamp in the promethean prm-25 projector
Make sure projector is unplugged and cooled down, lamp can be very hot
Remove the cover over lamp area
There are 3 screws in lamp unit (they have little arrows that point to them even) or check against new lamp to make sure you take out the correct ones
Pull straight up, place new lamp in securely and screw back down (screws are attached to each lamp set)
Place cover back over lamp area and screw closed
Reset lamp hours by hooking up your computer to board
Get to lamp reset screen
Press down up left right arrows in sequence then press return button in middle
Jan 26, 2013 | Promethean Board Lamp for PROMETHEAN PRM25...
I have a Sony model KDF-50WE665. Made a pop and the picture went out. I think it's been slow to come on now for a couple of weeks, so it's probably the bulb. Can you tell me: 1) Where can I buy...
The lamp you need is Sony XL-2100U ($78 at Amazon) or XL-2100 ($84 at Amazon).
Turn off the TV and wait a few minutes before you unplug it (let the cooling fan run). Then wait at least another 30 minutes before replacing the lamp. There are two screws on the rear panel (left and right sides near the top left of center of the small panels on the on the ends). Loosen the screws and then pull off the front panel (below the screen). The front panel has to be pulled off in stages - start at the right side and pull forward and down, then the left - pull forward and down and then the middle - pull forward and up. Loosen the screw on the lamp cover with a coin and remove the cover. Loosen the two screws that hold the lamp (use an allan wrench) and remove the lamp by pulling it straight out. Slide in your new lamp (handle with care - use a glove to avoid any oil from your skin getting on the bulb). Tighten the two screws. Then replace the lamp cover and tighten the screw. (Make sure that the screw goes into the unit straight - otherwise the safety lock may keep the TV off.) Reattach the front cover and then tighten the back panel screws. Put the old lamp in a box after it has cooled completely for disposal.
Pictures are available in the User manual here: http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF50WE655 . The appropriate section starts at page 16.
I hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Bulb "End of Life" message
hi,
for replacing the lamp do yhe following.
1.Remove the lamp cover by pushing two grooves lightly with the flathead
screwdriver. You can see the lamp cover on the top of the projector. ( left side of the lens)
2.Loosen the two screws securing the lamp housing until the screwdriver
goes into a freewheeling condition. The two screws are not
removable
3.Remove the lamp housing by pulling out the handle
4.Insert a new lamp housing until the lamp housing is plugged into the
Socket
5.Secure it in place with the two screws.Be sure to tighten the screws.
6.Reattach the lamp cover
7.Snap the lamp cover into place.
Replacing a new lamp automatically clears the lamp usage hours ok
Jan 27, 2011 | NEC MT1060 Multimedia Projector
How do i replace a bulb for kf-50sx300u
There are two big screws at lower corners of tv at rear side, open them with coin then pull out lower front panel, in middle you will see lamp door, open its screw with coin to see lamp housing, lose its two screws with hex-key and pull out old lamp. Slide in new lamp and put things in reverse order.
Lamp replacement procedure is written in user manual and explained with pictures, check page-28 to have better idea.
Click Sony Support link to download user manual free copy of KF-50SX300U if it is required.
Hope these info will help you.
Thanks.
Nov 10, 2010 | Televison & Video
Where is the lamp for sony lcd projection tv model # kdf-e60a20 located in the back?
To replace the lamp go to link below then click on operating instructions. then go to page 76. It will tell you how to change lamp.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDFE60A20
Dec 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
How do you remove the head lamp assembly on a 1993
1. Make sure headlamp is off and open hood.
2. Taurus model years 1990-1999: you must remove the whole headlamp to replace the bulb. Not a horrible task. Just annoying.
3. Facing the driver's side headlamp, and looking at the headlamp itself, at clock positions 8, 11 and 1 are the headlight housing screws. They all look the same. Using a 10mm socket wrench, remove these 3 screws and set them aside.
4. Just to the right of the "11 o'clock" housing screw is a bolt (same hexagonal 10mm sized top as the housing screws). This just needs a few turns to loosen it.
5. Gently pull the whole headlight forward. Now you can get at the bulb.
6. Disconnect the electrical connector from the bulb. Now the headlamp is free to work with. Remove the bulb, replace with a new bulb, make sure the bulb housing cylinder is in place and reconnect the electical.
7. Place headlamp back into position. Line up screw holes. Tighten the bolt. Replace housing screws and tighten.
8. Passenger side headlamp is mirror image of driver's side. Screws at 11, 1 and 4 o'clock positions. Bolt should be to the left of the "1 o'clock" housing screw.
Oct 12, 2009 | 1993 Ford Taurus
Chage lamp on Pt-43lc14-K
On the front, under the screen there is a large plastic cover. The far right side of the cover has the black decals "HDTV 1080i" and "VIVA bb3 sound" on it. There aren't any screws holding it on, just pressure snaps. Pull the sides of it off gently and the three or so foot long panel will come loose. You'll see a black plastic panel now with two doors, one in the middle and one on the left of the middle door. The one on the left has a white lamp warning label decal and a black screw holding it in place. Remove the screw and take off the door. Inside is the lamp housing. Some models have a a screw on the right side of the black plastic housing, holding it in place. Take out that screw and pull the housing directly out toward you. You now have the lamp housing. If you are replacing it with a new lamp and housing just push the new on into place and reassemble, you're all done. If you are replacing just the lamp, you have a little more disasembling to do. But its not hard. If you need further help, post a comment and I'll send pictures. Good Luck.
Jan 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Where is the lamp housing unit & how do I remove it?
The lamp is in the front of the TV. Pop off the gray cover, about the width of the screen, located just left of the power button. You will then see a bunch of warning labels on the left. Unscrew the one screw that is there and take that piece off. There's your lamp. Unscrew the screw on the right of the lamp and the lamp will slide out.
Nov 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Can't locate housing
The lamp comes out the front of the tv. There is a rectagle pice of plastic on the front that pops off and then there is a lamp door about 8 inches left of center with one screw in it. take that one screw off so you can get to the lamp, then take the screw out of the lamp and it slides right out.
Let me know if you need any more help!
Tim Nolan
Sep 12, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Mitsubishi wd62327
where is the lamp housing located?
Nov 09, 2007 | Mitsubishi WD62327 TV
Televison & Video Logo
74 people viewed this question
Jerry Greenberg
Jerry Greenberg
