Question about Fuji FinePix S304 Digital Camera
What is a zoom error on a j38 - Fuji FinePix S304 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 12, 2010
  • rickey0604 May 27, 2011
    This fix it worked and now I don't have to buy a new camera.
    Rick in Spring Valley CA
SOURCE: I just bought a FUJIFILM Finepix j38 less than a
u have a 1 year warranty. i would contact the business u bought it from because fujifilms customer service SUCKS
Posted on Nov 24, 2009
  • 11967 Answers
SOURCE: i have a Fujifilm camera finepix j38 and when i
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 12, 2010
  • 11967 Answers
SOURCE: Hello my barely used fujifilm fine pix J38 camera zoom error mess
Posted on May 03, 2010
  • 11967 Answers
SOURCE: Fuji j38 zoom error
Posted on Jul 23, 2010
SOURCE: Finepix j38 zoom error
I Fixed mine a few times what i did was turn it on it would scope out and back hold it and keep it from going to back in then go to pictures then exit it should be working fine now
Posted on Jun 06, 2011
Fujifilm j38 lens is stuck in the camera
You forgot to pull out after the lens was pushed in on the side. That mistake makes it very expensive to fix. If you buy the same parts camera with a bad lcd on ebay. You can have your good lcd replaced on the ebay parts camera. Replacing lcd is an easier job.
Mar 30, 2012 | FUJIFILM Cameras
Error 59.90
ETB motor start up error>Check ETB inter mediate connector J36 &J38, remove & reconnect them.>Check J1111 connector on DC controller remove & reconnect it.>Check ETB motor.>Replace ETB>Replace DC controller(Snap shot)
Dec 24, 2011 | HP LaserJet 5550DN Printer
59.90 hp printer error
Hi there
This is related to the ETB motor and you need to make sure if its working. Try the following
ETB motor error
1 Clean the ETB unit intermediate
connector, J36. If the connector is
damaged, replace it.
2 Reconnect the connetors J38 for the
ETB motor and J1111 on the DC
controller PCB.
3 Replace the ETB motor.
4 Replace the DC controller PCB.
Regards
Saleem
Aug 29, 2011 | HP LaserJet 5550DN Printer
I have a Fuji finepix j38. I went on the beach and it got a little wet and it wrote zoom error and now it isn't charging either.
Welcome to Fixya. Having a "zoom error" message is a camera malfunction, in this issue you can try to turn off and then turn it on again but this time you have to take care not to touch the camera lens or try not to blocked the camera lens while retrackting. If you still have the same issue you can try to visit this site for some steps you can do before sending your camera to your Fujifilm center.
In regards your issue about the charging of your battery,as you said before that you bought your camera to the beach. Try to clean the terminals with soft and dry cloth. Also, possible that the battery has reached the ends of its charging life. Purchase a new battery. If the battery still fails to charged, you have to contact your Fujifilm center.
Please let me know if you have any question.
Thank you for using Fixya.
seancarlisle
Apr 27, 2011 | Fuji Cameras
Everytime I turn my fujifilm finepix j38 on it says protected card. I can't take pictures erase pictures....nothing. How can I fix this problem?
Your camera uses an SD type card so on the upper left side there is a white sliding switch make sure this switch is pushed forward to the top (towards the gold contacts) to put it in the unlock position.
Dec 23, 2010 | Fuji J38 Digital Camera
I have a Fuji finepix j38 that is appox. 8 months old. When I turn the camera on, the lens comes out, immediately retracts, and "zoom error" comes up on the LCD. I can view pictures, but can't take any. ...
I thimk your problem is that you have sand betwin the lens mechanism and that cause the immediately retract.you can try to apply air pressure near the lens but with care
Oct 05, 2010 | Fuji Cameras
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
My fujifilm finepix j38 has a zoom error
Were you able to fix this?? My camera has had this error for over a week now and I cannot figure out how to fix it...
Feb 09, 2010 | Cameras
Oct 09, 2009 | Fuji FinePix S304 Digital Camera
Fuji FinePix S304 Digital Camera Logo
443 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
