Question about Garden
Model rzt 185380bve fuel solenoid shuts off
Modwl rzt 185380bve fuel solenoid shuts off
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
Where are the solenoids for the fuel
    Small Engine Repair: How to Check a Solenoid Fuel Shut ...
    ? 4:40
    https://www.youtube.com/watch?v=Kr6UayxyVwU
    Jul 23, 2011 - Uploaded by smallengineshop
    Solenoid fuel shut off valves are used to close the main jet or main fuel circuit in the carburetor when the key ... images for Where are the solenoids for the fuel
Nov 22, 2015 | Cars & Trucks
Is there a filter or screen in the carburetor?
Remove fuel line from entry side of filter, after shutting off fuel. Turn the fuel on, see if there is fuel flow to the filter. If there is insufficient flow. There is trash blocking the discharge port in your fuel tank. If there is fuel flow at the entry of the filter, repeat the same steps for the outlet of the filter. if no flow replace the filter. if fuel flow is ok, you have a bad fuel pump or The fuel pump is powered by Vacuum you may have a loss of vacuum to the fuel pump.
Jul 21, 2015 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
I have a john deer stx38 fuel shutoff solenoid is bad can I bypass this
Unless the solenoid is shorted or opened electrically; or physically damaged have it ultrasonically cleaned. No chemical dip as it will damage the enamel coated wires.
Removing and bypassing can cause exhaust system damage from raw fuel igniting in the exhaust during shut down.
Apr 19, 2015 | Garden
Fuel shut off solenoid problem
Check your oil..... If solenoid sticks open fuel will continue to run when engine is off and will fill up crankcase with fuel. This a cheap way to fix this problem. Go to a shop or parts store and buy a fuel shut off valve, like on a snow blower. Find fuel line then install. But always remember to shut off after use or you will have same problem.
Jul 14, 2014 | Mtd Garden
Fuel shutoff solenoid
You have an A1 control board issue, but you never indicated what generator model, power is momentary to the solenoid during cranking, and then picked up by the control board in the run circuit
May 19, 2013 | Onan Cummins 146-0646 Solenoid Repair Kit...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
When I turn the key to shut the engine down it
I don't think the starter solenoid is involved here. T
There should be a fuel shut off solenoid on the bottom of the carburetor which shuts off fuel when the ignition is turned off -- this is a safety feature as well as protection from damaging backfiring.
This fuel shut off solenoid could be stuck open.
There is a switch under the seat which opens and closes the solenoid depending on whether the seat is occupied. This switch as well as the ignition switch control the solenoid.
May 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
