Question about Dishwashers
I am getting a white powdery substance on dishes - i tried a dishwasher cleaner, cascade gell, finish powder and jet dry. help
  • Dishwashers Master
  • 43,501 Answers
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My kitchenaid dishwasher is not cleaning as well as it use to. The dishes do not "feel a finished clean". It's like it's not rinsing all the soap off and they're just not clean...
Hi wesalado,
Please follow my Tip below on some hints on how to keep your Dishwasher in tip-top shape:
DISHWASHER NOT CLEANING PROPERLY ANYMORE...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 03, 2011 | KitchenAid Dishwashers
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 10, 2010 | Whirlpool DU805DWG Dishwasher
I purchased a dishwasher in dec.07. I am not happy! My dishes are not clean! Silverware and glassware have a white coating on them. I've tried less detergent(cascade gel and powder)I tried more. Done the...
Did you try to adjust the doseage regulator that is in the jet dry compartment fill hole, check your operators manual for info on this.
Good Luck !
Mar 16, 2010 | Dishwashers
My dishwasher does not always dry the dishes completely - even though I use the same cascade with each use.
The most important thing to getting the best drying from this energy efficient, water conserving dishwasher is keeping the rinse aid dispenser filled. In my part of the US, I only see a rinse aid called Jet Dry.
The Cascade is the detergent powder and will not help the dishes to get dry.
Note: Even with the rinse aid full, some plastics will still be wet.
Aug 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
Having a problem with a white powdery substance Model 17602
The sump may be full of debris here is how to check it:
ok in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Nov 28, 2008 | Kenmore 24 in. 17602 / 17604 / 17609...
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 | Dishwashers
Dishwashers Logo
90 people viewed this question
Top Dishwashers Experts
