Question about SanDisk Sansa E280 MP3 Player
MP3 player can't find music.
I was playing music and everything worked fine. I plugged it in to recharge once this was completed. My music would go into "bad track" and the sandisc would lock up. I would plug my computer into it and it would not show up. I ran fix-it from the disc, it now shows the scandisc but keeps seaqrching for my music.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
TrekStor emo won't show or play mp3 or WMA files.
I had the same problem. The solution for me was that the files on my computer hard drive were set to play on the realplayer format. Once I changed the format to play on the windows media format, it started saving to the Emo. I hope this helps you.
Dec 16, 2008 | Trekstor 74412 i.Beat emo MP3 Player
Audio is messed up!
First, make sure you didn't download an instrumental.
Second, make sure the files are in a format that the player recognizes.
If both conditions hold, then upgrade the firmware - you have a corrupt DB.
Sep 08, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 Player - sansa sandisk 2 GB
Unfortunately you are not going to be able to go online to sync your device...All music subscription such as napster and rhapsody require you to sync your device every single month using their actual software..The reason is to prevent customer from cancelling their music subscription..once you cancel your membership all the songs you have on your device will become useless.In another word, you are renting the music from the subscription company...
P.S.Please rate accordingly...
Thank You
Computerrep
Jun 17, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
It won't let me play my music!
no worries. there may be a read error. if it still connects to your computer fine download all of the files, movies, mp3, mp4 etc back onto your computer. once you have done this go into the file holding all of the mp3's and set the file to show details and look for a mp3 that is the incorrect file size... in general comparison to the other files. also if the device came with software look around for a restore factory settings button or wizard, and once the device is completely clear restart it and reload the files back onto it, remove the device (safely) then switch it off and back on and then try it out again. hope things work out bro.
Sep 22, 2007 | SanDisk Sansa e260 MP3 Player
Not playing music
No Music Files Problem solved
Plug the MP3 player to PC
In Windows XP open Windows Explorer and navigate to one of the music files
Try to play the file in Windows
If it fails, unplug player and once the player switches off carry out a reset
Reconnect player to PC and repeat the process described above
You may need to repeat this several times until the music file plays in Windows.
After this format the player using Windows XP
Select the removable hard drive, right click and select format
Choose Fat32, enter a volume label (for example GMP33005) and select quick format
If formatting fails try several times
Once format is succesfull reload your music files using the software that came with the player
Be careful not to exceed 2.5 or 2.6 GB (leave some free space as this might be needed for the player to work)
The player should now play the music files correctly
Sep 22, 2007 | Audio Players & Recorders
Cannot charge or copy music onto the sansa e270
You might not have the battery "seated" correctly. Try removing and replacing the battery.
Sep 04, 2007 | SanDisk Sansa e270 MP3 Player
Not playing music
It happened to me once before. So I formatted it threw the program that came with the device and then I copied my music files once again while the program was working. After that everything worked just fine. Hope it helps!!
Jan 05, 2006 | GPX M2104 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
