Question about Kenmore 22422 Top Load Washer
My washer wont spin tries makes noise to flipped it over to check it out was hot to tuch
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since top load and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. Can you hear the motor???? Can you smell anything like rubber burning??? Will it drain????? What is hot, the motor, pump, transmission????
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 28, 2010
GE WDSR2080D5WW wont spin or agitate
The coupling might be bad. Take cabnet off by removing 2 screws from counsel, then flip up and pop 2 clips and the cabnet will pull away from machine. Then pop 2 clips off pump down in front of machine then take the 2 quarter inch screws out of the 2 clips holding motor then you'll see coupling. Any questions call Chris's r Repair at 716-258-1944
Dec 21, 2011 | GE WDSR2080D Top Load Washer
Washer wont spin or empty I think the switch is broken how do i get the top off?
Flip up the controls, pop the S clips, unplug the lid switch connect. Tip the case toward yo and lift it out the way,
themobilian_2187.jpgthemobilian_2188.jpgthemobilian_2189.jpgthemobilian_2190.jpgthemobilian_51.gif
Jump the 2 hot wires to check switch operation and look for leaks and noises while the case is off.
Videos and more HERE
Apr 09, 2011 | Kenmore Washing Machines
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
I have a washer that makes a loud screeching noise
flip your washer over and there is a v-belt between the tub and a motor it either needs to tightened or its too tight
Jan 12, 2009 | Washing Machines
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Barberboss
need more details please stopped what wont fill wont spin wont drain does it make any noise ?? does it fill and not wash
May 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Motor wont spin
whats makes the noise on spin if motor not turning at all.. i kinda confused... I Would check lid switch and see if maybe that might be the problem.. havnt had a lot of experince with hover but most washers have lid switchs to prevent spinning when lida opened
Sep 02, 2007 | Hoover AAA140 Front Load Washer
Kenmore 22422 Top Load Washer Logo
48 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
