Question about ASUS P4S8X Motherboard
What is the fastest processor that can be used with this motherboard?
  • Paul Moffat May 11, 2010
    It takes Intel Pentium 4 CPU, socket 478 with a maximum FSB of 533mhz. An Intel CPU that matches those specs should work.
  • ASUS Master
  • 11,800 Answers
 3.06 GHz Pentium 4  with Northwood core. Newer ones will not be recognized by the BIOS.
Posted on Apr 26, 2010
HOW MANY TYPES OF MEMORY SECTOR IN MOTHER BOARD
1) The Processor has the fastest memory. It is the Cache.
(L1, L2, and for some Processors, L3)
Operates at the same frequency rate ('Speed'), as the Processor.
It is a small memory area for the Processor.
2) Next is the Ram Memory. Random Access Memory.
Ram memory typically operates at HALF of the Processor's FSB.
It is the second fastest memory on the motherboard.
3) Next after the Ram Memory is the Harddrive.
Harddrive's have a Buffer.
Buffer is a Cache for a Harddrive. A small memory area.
The Harddrive is the third fastest memory.
Regards,
joecoolvette
Sep 08, 2012 | Computers & Internet
I need the best, fastest, most powerful and recent CPU and RAM available for the AcerPower Series 661GX-M7 motherboard; can it use a dual core processor?
Welcome to Fixya. If you want to upgrade your Processor you can use a dual core cpu. I proivded the list of processor that is compatible with your motherboard. By the way the socket of your motherboard is a LGA 775
Lga 775 Processors
Thanbks for using Fixya.
Jul 02, 2011 | Computers & Internet
What is the fastest processor I can upgrade for Gateway E-6000 ? I try to upgrade memory, but they r just too expensive
first check to see what kind of motherboard you have. then use google to search for that motherboard, and from there it should tell you the fastest-supported processor.
Feb 23, 2011 | Gateway E-6000 PC Desktop
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
What is the fastest processor this board will handle?
i thought
Intel i845PEis fastest processor for your board
Feb 12, 2010 | Soyo SY-P4I 845PE Motherboard
What is the largest and fastest hard drive that will run on the Intel 845PE motherboard?
That motherboard is so old I couldn't find any information about it except that it uses a Pentium 4 processor and has an AGP 4x slot. The processor itself is an immediate bottleneck and since you have an AGP slot, you most definitely are using ATA and not SATA.
To make use of the, "largest" and, "fastest" hard-drive(s), you would have to buy yourself an X58 motherboard with an i7 processor. Which I doubt you want to dish out that sort of money.
So instead, this is perhaps the fastest and the largest hard-drive your computer will be able to make use of:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136111
If you want to view all available hard-drives, visit this website. Afterward navigate to Computer Hardware>Hard Drives. Now on the left select, "Internal Hard Drives." Now on the left select, "IDE Ultra ATA100" located under, "Interface."
Those are the only hard drives your system can use, and out of those I already showed you the fastest one.
Let me know if I can help you further or if I can explain anything I mentioned above in more detail. I'm sorry you can't use the latest and greatest, however those are designed for the fastest systems on the market.
Mar 16, 2009 | Gigabyte 845pe (GA-8PE800PRO-R)...
How fast of an amd athlon processor can i use in a biostar m7mkb?
According to these specs 500 Mhz and up
http://www.motherboard.cz/mb/biostar/M7MKB.htm
Your motherboard supports a slot A Athlon.
The fastest looks like up to 1Ghz as according to CPU World:
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20(Slot%20A).html
Hope this info answers your questions. Feel free to comment if you need further info from me.
Rate me please when you get the chance.
Mar 04, 2009 | Biostar Slot A M7MKB Motherboard
Processor up grade
The fastest cpu you can use on your mb is a pentium 3 800. Providing that you have the latest bios update.
check this link here.
You may need to download and install bios update from factory website .
Feb 22, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Fastest socket A processor?
i think you will find that you are in fact using the fastest speed processor for the socket 'A' type of motherboard as AMD has changed to socket 754 or 939 for dual core processors. You can clock the speed a little in the bios, if you go to the peocessor section in the bios and look at the clock speed probably set at 133MHZ you can move it up 1 increment at a time, eg 134MHZ and keep trying until the pc wont boot up, at which point you will have to reset the cmos settings JBAT1 terminal and then set it again to the fastest you got it to before it wouldnt boot.
Aug 31, 2007 | Syntax SV266A SKA KT266A Motherboard
Looking for the best/fastest processor for this board
http://www.neoseeker.com/Hardware/faqs/kb/19,47.html try this link!
Apr 06, 2007 | Syntax SV266AD Motherboard
ASUS P4S8X Motherboard Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
