Televison & Video Logo
Posted on Apr 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pvr goes from on to off several times at start up. Also often deletes recorded programs.
Mike.H-DISH_Network
Level 2:
  • DISH Network Expert 246 Answers
  • Posted on Jan 02, 2011
Mike.H-DISH_Network
DISH Network Expert
Level 2:
Answers
246
Questions
0
Helped
90904
Points
341
Hello brent_legget, my name is Mike Houston of DISH Network customer service. I want to say sorry you're having that issue; there are things we can check on that. First we want to make sure the receiver is plugged directly into the wall and let the receiver power up on its own. Once the receiver powers up, we will want to check the DVR and try to check recordings. And if the problem still persist please reply to this post so I can help further.
Thank You
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
96
Points
All my recordings (30 + hours) were erased after a power outage!
Can I get it back??
Please help
1helpful
How do we pre program our Rogers PVR so we can record new episodes of our favorite shows without haveing to program on a daily basis
You cannot program the PVR to only record the new episodes with this unit. However, you can set it to record all episodes of a program. Press the Rec button on the remote. Select your PVR that you want to have record the program. Use the arrow keys to navigate to More Recording Options. Select All Options. (Note: if your program is moved by the channel programmers, the show that airs instead will be recorded by the PVR.) This is shown here: https://connected.rogers.com/how-tos/posts/get-connected-with-rogers-whole-home-pvr-626435 .
I hope this helps.
(I've set my DVR to do this for only a financial news show that doesn't have repeats.)
1helpful
What does [ time shift speed ] mean? And in Pvr it always displays c. Drive. It it won't allow selection of usb. It displays [ usb 0]
Time shift speed on a PVR usually relates to the speed of the recording. It depends on how fast you want to fill up your drive. The faster the drive fills up usually gives you a better quality then a slower recording speed.
As far as the USB goes. "USB 0" is usually the first USB connection. Some electronic devices and electronics in general start counting at 0 not 1. Just plug it in the USB port and select USB 0. It should work for you.
How do i erase a hdd recorded program on my dvdr3570h which shuts the recorder down every time i click on it
It is corrupted - do not start it but from options DELETE it. If nothing else helps, reformat the HDD.
Bauhn Manual for APVR-9650T
http://forums.whirlpool.net.au/archive/2211037
Quoting from above:
Bauhn 1TB PVR
model APVR-9650T
a REVIEW
Spent a couple of hours with this PVR, comparing it with an earlier model Bauhn 1TB PVR (AS-PVR1000R, 2011).
Bought on sale Wednesday, $199.
[Only commented on differences between models. Have previously reviewed the older model - which still is a reasonably good PVR.]
Summary: not bad, some good features in a budget PVR, and a couple of annoying issues that weren't in older models (which should be easy to fix in firmware). Works well, responsive remote, although I prefer the button press of earlier model.
But product quality control is worryingly patchy. Bought 2 units, 1 was dead out of box!! Confirms my advice to buy 2 to get 1 that works well. (On power up with good broadcast signal, TV displayed Bauhn logo for few seconds, then blank screen, sound of HDD, and never advanced past "----" on PVR. Tried many times on different video outputs & TVs.)
I'll probably be returning this PVR within 60 days as the few annoying aspects outweigh the added features for my needs, over my older BAUHN PVR.
Features:
Series Record:
Records all programs with that title on that network. (Still assessing if SERIES RECORDs program on more than 1 network - e.g. records Simpsons on 10 & 11, but does it SERIES RECORD Mythbusters on SBS, as well as 7Mate?)
Good if you are away from PVR as it changes recording times to latest EPG (as long as broadcast sticks to EPG times), if program schedule frequently changes, and does not record if program is dropped from schedule.
(I have returned from overseas to find what I had set to record was not what was recorded as the program line-up had changed. SERIES RECORD should solve that.)
But... takes up many available recording schedules including ones you may not want recorded (PVR has maximum of 50 TIMER schedules, so for example SERIES RECORD "QI" on ABC1 - with 13 episodes/wk, would occupy over ¼ of available schedules!).
Also you cannot pad these recordings - adding a few minutes before/ after in case program starts early/ ends late. Changed recording time may conflict with other recording schedules meaning program may not record (check by EPG Search). Takes some getting used to to ensure consistent recordings.
Setting up standard weekly etc TIMERS may be preferable & more predictable.
EPG Search:
Searches for all programs by title within 7 day EPG, on all channels. Shows & allows setup of recording schedule, and if there are conflicts between SERIES RECORD & recordings, to set Priority.
Scheduled Recordings from EPG:
Settings for recording Once, Daily, Weekly, Weekday/ Weekend.
You can pad scheduled EPG recording times by up to only 10 minutes, in case program airs early/late.
(The older 1000 model can pad up to many hours - e.g. to record multiple consecutive shows on 1 recording, and the recording date can be changed to skip that particular recording. You can manually set up recordings to achieve this on this PVR, but then lacks program name, which you can rename. An advantage if you are running out of schedule recording slots.)
Time Shift:
Up to 2 hours, which is adequate. Can set to always be on, so can pause/rewind live programs when you wish. (1000 model can be set to almost limitless Time Shift. Mine is set to 4 hours.)
Editing Recordings:
Editing would suggest removing unwanted sections, but this PVR simply marks sections of the recording for viewing, skipping the unwanted. The file remains the same size, and copying the file to another device leaves the original unedited recording.
Settings:
MENU-PVR Settings: (handy when setting up)
Set Time Shift length (30-120 min) + Time Shift Function (Disable / Enable)
Playback Start Position (Beginning of program / Continuing from where you were watching) Continuing is handy.
Auto Play Next Program (Disable - stops playing at end at end of recording / Enable to watch recording then next recording )
MENU-Settings:
Audio&Video Output Settings
(set to suit your TV etc)
Time (by State & Daylight Saving - otherwise EPG & recording time will be incorrect)
Channel List (press OK during live TV):
Can delete unwanted channels (which the 1000 model annoying could not).
Can set up 1 set of Favourite channels
External USB Storage:
2 USB (1 front, 1 rear) capable of accessing larger HDD (tried with 3TB) formatted as NTFS or FAT32. So quite useful, as I found on 1000 model.
Copying is painfully slow. On 1000 model, crashes occurred when storage for recordings was set to a USB device (MENU-PVR-PVR Setting-Recording Storage) - don't do it!
USB drives less than 16GB can't be formatted on PVR.
WARNING: If PVR freezes (too high load on processor like copying too much or Copying + Recording) while writing to external HDD, HDD may be corrupted when you are forced to unplug PVR from power! (Have had Seagate HDD totally corrupted twice with 1000 model - files cannot be recovered due to storage method). Best not to copy too much at time to HDD!
Networking: (Not assessed yet)
Via Ethernet cable. Can access recordings, photos, music on PC, and transfer to PC from PVR. Access is typically MUCH faster than to USB storage. But requires files to be in set folder, which may be unsuitable.
Media Player (Not assessed yet)
Photo & Music Players have been added . Playing MP4 files is not great.
Annoying aspects...
OSD can't be hidden when using Pause
Pausing live program, or recording leaves an information box on screen - there is no way to remove it. Pausing a recording is something I regularly do, to view details. The PAUSE bar includes the EDITING tools, making it larger than normal. As the on-screen-display covers nearly 20% of the screen, at the bottom, subtitles and information bars broadcast with the program can't be seen! You can only increase the Transparency, meaning you can see through the OSD (MENU-Settings-PVR Setting 1-60%). However, setting a high level of Transparency makes using any OSD difficult.
Slow boot time
It takes about 35 seconds to.power up from Standby to fully operational. While that is marginally faster than the older 1000 model, it is slow.
Slow navigation within EPG, Timer & Media Browser etc
There are no P+/P- (Page up/down) buttons as on 1000 model. Moving up/down a list to select between possibly hundreds of programs (recordings) is SO slow - moving 1 at a time instead of a page at a time. (Strangely the P+/P- can still be found in the onscreen keyboard when you Rename recordings or do an EPG Search. There it performs a keyboard shift function.)
Slow navigation within Recordings & Time Shift TV
FF/REW speed is a maximum of 32X, against 64X on 1000 model.
There is a very handy undocumented feature of FF/REW by holding down the right/left arrows - located around the circular OK button (while watching your time position on the progress bar). Handy for moving quickly to position in program or skipping ads. (I found this on the earlier 500 & 1000 models.) However it is SO much slower to FF/REW on this model.
Bright Standby light
As in the older model, the very bright blue light can be annoying, but easily fixed with a small piece of black electrical tape or similar.
PVRs take time to discover their flaws & features, so I'll keep exploring ;-)
Aug 10, 2013 • Cell Phones
Sagem PVR disk full error
Most likely a hard drive failure. Something called spinal failure can cause an issue that sounds like this.
I can't delete a specifc program that I recorded on my Shaw PVR
Select the program, and start watching it.
Press the PAGE-UP button to "fast-forward" 5 minutes.
Do it again and again, until a window shows up: DELETE or NOT DELETE.
Select DELETE.
19helpful
2answers
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
Motorola Dual Tuner PVR - DCT 6412-III --- HELP
I was just reading another blog on this problem and it seems you must clear any recording setup you have for the program the go to the settings and in the history file delete all listings of it. This can take a while as you must delete them one at a time. Then you can reset the series or single recordings. Seems to work for some people. I am having the same problem and programs are disapearing one at a time. Good Luck
Smalltown
Motorola Dual Tuner PVR 6412-III ( HD )
If you cannot get it repaired, note that it has a 120GB disk-drive -- very small when compared to the latest model (500GB), and note that the disk-drive probably is approaching 10 years old -- doomed to "fail" soon. Replace it, and add an external-SATA "Expander" to add another 1000GB of storage of recordings.
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
