Question about HP PhotoSmart 7350 InkJet Printer
HP 7350 assert error 0310e5e8 -- what does it mean? won't print -says insert paper and yes i have paper
StephJohn
  • 10 Answers
SOURCE: printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Posted on Mar 18, 2009
  • 3 Answers
SOURCE: hp 2015dn paper jam light on solid,won;t print
There is a manual paper release on the bottom of the paper tray. If it gets stuck the paper does not rise to be picked up. Not sure why it registers an amber paper jam for it, but I taped my release open and put the tray back in carefully. Its been working for 2 days straight now.
My real issue was I had both the low toner and paper jam lights on solid and amber. I waited a few days to post this to make sure it worked. Worth a shot for you all. post back if it works for you .
-T
Posted on Feb 27, 2009
SOURCE: hp printer
Thanks for being there, guys. I was freaking out because I wanted to print my boarding pass to fly to San Francisco for a family dinner.
A friend came over, unplugged the printer, replugged it and MAGIC! It worked. I'll remember that next time altho' I don't know why that happened.
Thanks a bunch.
auntlinduh
Posted on Apr 12, 2009
  • 109 Answers
SOURCE: hp photosmart 7350-cannor print from emails or any
As far as I remember, HP has the actual print nozzles built into the cartridge itself. Part of the reason their cartridges are so expensive. The trick that I use is fold a paper towel into quarters (fold in half. then fold in half the long way, again). This should now be about 1/4 the original size. You want it 4 layers thick so that the ink doesn't soak through and stain your counter top or whatever. Moisten the folded paper towel with warm water (doesn't need to be hot) and hold the print head part of the cartridge against the wet, warm towel. This will soften the ink and allow it to flow again. Check to make sure that there are ink marks on the towel where you had the head area placed. Dab the head on a dry part of the towel and replace it back into the printer and run the head cleaning utility. This has always solved my HP cartridge ink flow problems, uses less ink than the cleaning utility and keeps the heads from getting messy by not running the cleaning utility 4-5 times in a row.
Posted on Jul 15, 2009
  • 61 Answers
SOURCE: My HP Photosmart 7350 was working fine. All of a
service your product
Posted on Aug 19, 2009
I get an assert error code c00e701 on my hp 7350 how do I fix it
im not up to speed with this type of error or what its associated with
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope it helps
Jun 05, 2012 | Microsoft Windows XP Home Edition
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Hello I currently have a 2 GB memory card in my canon SD 1000, camera i want to upgrade to 4GB memory card, what is the best brand or type? Will 4GB SDHC memory card work with my canon camera? ...
The Canon SD1000 will work with SDHC cards, up to 32GB in size. Stick with any of the major brands and you won't have problems.
The HP 7350 will NOT work with SDHC cards, limited to SD cards 2GB and smaller.
Mar 26, 2011 | HP PhotoSmart 7350 InkJet Printer
I have an hp photoshop 7350 with an error message of "Print cartridge cradle is stuck". Can you help?
Good day!Try to see if there is a foreign object that made it stucked..try cleaning the ink in the carrier of your cartridges..
feel free to ask..
mastergani
Mar 26, 2010 | HP PhotoSmart 7350 InkJet Printer
The kodak gloss paper gets jammed in my hp photosmart 7350 printer towards the end of printing photos
You have an HP printer. I highly recommend you use HP photo paper for the best results. This may not solve your jamming problem but it may. HP printers are very touchy as to what photo paper you use.
Nov 24, 2009 | HP PhotoSmart 7350 InkJet Printer
My HP 7350 Prints Almost Nothing
You should try going into the properties and running the head cleaning that will fix ya right up
Aug 27, 2009 | HP PhotoSmart 7350 InkJet Printer
What is error 0310e5e8?
Need a little more information. What OS, and does it happen when you try to print something? At first blush this sounds like it may be corrupt drivers...
Jul 18, 2009 | HP Photosmart D5160 InkJet Printer
Printer stopped printing durring project "Assert Error b52b00b4"
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
HP PhotoSmart 7350 InkJet Printer Logo
583 people viewed this question
Seeker5211
Seeker5211
