Question about Evga e-GeForce 6200 GeForce 6200, (256 MB) Graphic Card
Hp wont accept gpu
I bought the 6200 256 and installed it in an older 03 hp a305 modle. at the end of the installation the monitor would click off or cause smears. the system is running a celeron cpu @ 2.70 ghz and upgraded to 1.24 gp ram. I bleave the intell graphic controller may be the source, not sure.it's a intell 82845g/gl/ge/pe/gv.. hope u can help.
thank u
  • 80 Answers
Hi im wesley. you are rite it is the video controller try downloading the latest version of the graphics card it mite work but i doubt it i have the same laptop and the same problem the laptop i think doesnt support it in some way but a smaller graphics card does work
Posted on Jul 11, 2008
How to increase resolution from 1024 x 576 pixels to 1280 x 600 pixels. I tried to change it by clicking start>control panel>display>settings but won't get desired results.
make sure wether the disply of your monitor and graphics card supports the resolution if the monitor doesnt support sthe resolution you will not be able to increase the resolution the mobilor becomes black
Sep 04, 2011 | HP Mini 1000 Netbook
I have bought e games MahJongg Master 6. Have run the disc to install but the game wont run, tells me Cannot initialise graphics and cannot install graphics device. My system is HP pentium 2.7GHz, 2GB...
Mahjong 6 was produced in 2004 and will likely not be compatible with your operating system, operating systems that are 64bit are often less compatible with software than operating systems that are 32bit, especially with older software. One solution you can try is to:
  1. Right click the desktop shortcut for the game
  2. Click "properties"
  3. Click the "compatibility" tab
  4. Check the box next to "run in compatibility mode for"
  5. Select Windows XP
  6. Click Apply
This may allow the game to run by emulating an older operating system.
Mar 14, 2011 | eGames MahJongg Master 6 for Windows
I bought a lcd monitor samsung syncmasterB1930 and it requires 1324*1068 screen resolution. i have installed the drivers for the monitors but still unable to get the desired resolution. is there any way...
The native resolution if this monitor is 1440x900 - i have no idea how you end up with that weird resolution. In any way it will not accept a higher resolution.
Nov 23, 2010 | Asrock 775I65GV...
I have a hp officejet 4110 bought in '03. Will this work with windows7 ?
Yes, it will. Go to: www.hp.com
Click the Support and drivers section
Click to download and type the model in there. Choose the correct model, then choose Win 7 Operating System.
Download the "Full feature software and drivers"
Unplugh the printer from the pc, start the installation of the software you downloaded and when it asks, plug it back in, finish the install and your done! :)
Cheers!
Oct 28, 2010 | HP Officejet 4110 All-In-One InkJet...
Hp, pavillion DV2000, computer turns on, monitor is black
The problem is most likely a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Apr 21, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion F1903 monitor flashes on and then screen goes black. I have read countless posts about backlight issues but I cannot see the screen with a bright flashlight. This happened some time ago and I...
Can you check the temp. of your CPU and GPU? If your GPU runs 80 grad C, you have a overheating problem. The problem is a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Feb 11, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Hi, I bought some expired ink on line and my HP d145 won't accept it
the printer will not accept it, have it return where you purchased and tell them that you have recieve an expired ink cartridge and your printer wont accept or charged it when it is installed, send it back and have it replace
Dec 07, 2009 | HP OfficeJet d145 InkJet Printer
Scan will not work
Step one: Make sure that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon (c01387841.gif ) normally appears in the Notification area at the lower-right corner of the computer screen. The monitor is ready when a check mark appears on the icon after you start the computer. If the Digital Imaging Monitor is in the system tray, skip to 'Step two: Populate the Destination List.' If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig , and then click OK .
  3. In the System Configuration Utility window, click the Startup tab.
  4. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. You need to reinstall the software. Click here to go to Step three: Uninstall and reinstall the software .
  5. Select the HP Digital Imaging Monitor check box.
  6. Click Apply , and then click Close .
  7. Click Restart to restart the computer.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to fill out the destination list.
  1. Open HP Solution Center with one of the following methods.
    • On the Windows desktop, double-click the HP Solution Center icon (c01425508.gif ).
    • On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after you turn on the printer or computer.
  6. Click each program to include on the Scan To list.
  7. Click the Add arrow.
  8. Click OK .
  9. Scan a document using the Scan To button on the front panel.
    • If the scan fails, try to scan using the HP Solution Center Scan button.
    • If the scan still fails, continue to 'Step three: Uninstall and reinstall the software.'
Step three: Uninstall and reinstall the software Uninstall the software
  1. Unplug the USB cable connecting the product to the computer. CAUTION: Do not reconnect the USB cable until the on-screen instructions prompt you when you reinstall.
  2. Click Start , click Control Panel , and then double-click Add or Remove Programs .
  3. In the list of installed programs, click the HP product, and then click Remove .
  4. Follow the on-screen instructions to complete the software removal. NOTE: If asked to remove shared files, click No . Other programs that use these files might not work if you delete the files.
Reinstall the software
  1. Turn the product on.
  2. Open a new window to browse to the Select Software and Drivers page:
    1. Right-click this link, Select Software and Drivers , and then click Open in New Window .
    2. If prompted, type your product number. You might also need to click it in a list of similar products.
    3. Click your operating system. (If you do not know, click Start, right-click My Computer on the menu, and then click Properties .) The Select Software and Drivers page opens.
  3. Click the Full Feature Software and Drivers option.
  4. Click Download only . This option allows you to install the software at any time after the download completes.
  5. Click Save , and then browse to the location on your computer where you want to save the file.
  6. Click Save . The software downloads to your computer.
  7. When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe
  8. You can accept the default location to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  9. When the Install Wizard starts, follow the on-screen instructions to install the software. Important : If you choose a Custom type of installation (available for some products), make sure to install HP Imaging Device Functions so that you can scan from the printer. The Recommended installation type installs this feature automatically.
  10. After successful installation, scan a document
May 08, 2009 | HP Photosmart 3110 All-In-One InkJet...
New video card installed, now monitor won't work.
  • A vary basic failure here.
  • the OSD tells you , pin1,2,3,13,14 are dead but that is what sleep does. kills video and sync.
  • no PC stated
  • no OS stated. windows 10? what? why must beg.
  • did you turn off all sleep and hibernate in your power manager
  • click CP, click power settings click custom power profile and set all that to OFF, do not turn off screen ever. XP to now.
  • did you look in this CP control panel, DM monitor list>?
  • see my monitor, its there and not bad, if it shows bad .
  • if f1903 is missing there then your OS does not support it.
  • Right click it (internet must be connected) and say up date driver and let W10 find your driver for your OLD monitor.
  • Did you know MS drops old hardware that the maker does not support now? this is all in the PnP rules sets. but on monitors there are magic tricks to fool the system if true. this.
vga-eqk4kg0rieheuxmlwixke1cc-1-0.jpg does your monitor work on others PC, with same OS
do tell that.
does your pc work with other monitors. bingo>?
is that hard to do find another VGA port, to try, ? on someone elses PC, we cant do that here, so..... only you can do that.
hp supports it
and has this program to run and test your display
http://support.hp.com/us-en/drivers/selfservice/hp-pavilion-19-inch-flat-panel-monitors/447429/model/348757#Z7_3054ICK0K8UDA0AQC11TA930O2
last and best
ever call up BIOS?
boot pC and hit the BIOS key, called BIOS settings menus.
(HP F1,F9,10, or ESC) hint , it prompts you at boot.
does that work? omg it does so VGA is ok. right. 99% sure.
all in 5min work. you see it works
and then dies in windows x (what ever your X is)
if it dies in windows, here is the cause, (all causes)
VGA card is not bad, or overheated. bios works
1: windoz is virus infected tops that list. endless, to a fault.
2: PNP to dead, it plug and played, and killled the monitor driver or vGA driver, (less much less in w10,)
3: bad video drivers. (if hp get them from HP !)
4: internet dead, cant run PNP with no internet. not and win.
5: newer system DT< with expensive video cards the power jack cables fell off (this is only on high powered DT, like a Ausu M5a90x.
5b same deal video fan dead. overheated now.
6: PC goes to sleep, and is not anything to do with WINDOWS sleep
did you know the CPU has a sleep mode, it shuts down overheated.
some GPU do the same using the same magic hidden electronics in the GPU
if you had told what PC it was, id not have to broad band my answers. im sure i missed more,,, lacking
PC tag words.
or OS name and build.
Mar 29, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
My new hp officejet pro L7590 printer tells me that "no scan options" are available. I bought this as a all-in-one printer. help, I need to scan
Hi Kate,
This error occurs if HP drive services are not functioning properly, so try my solution
Solution
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
Jan 13, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Evga e-GeForce 6200 GeForce 6200, (256 MB) Graphic Card Logo
Top Evga Computers & Internet Experts
Tony
David
David
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
