Question about Scosche Industries Fd134030b 96+ Ford Taurus/Sable Kit
96 ford taurus is hard to shift out of park. The fuse is ok. I have to press the brake many times and just keep working with it. What could be the problem?
  • 2 more comments
  • baccuscaroly Apr 25, 2010
    Where is the solenoid cable located?
    where is this cable located?
  • yadayada
    yadayada May 11, 2010
    on the end of the solenoid, the solenoid is bolted to the top of the steetring column which u must drop down to access it, there are two 15mm nuts on studs that hod it up to the dash, remove the lower dash panel under the sterering cloumn to access the two nuts, once it is down u will see the little solenoid.
  • yadayada
    have you checked to see if the park lockout solenoid cable is free moving?
I cannot shift out of park. My foot is on the brake, but the shifter will not move
You have a park brake release solenoid not working, there are several ways different car manufacturers have for manually releasing. But I would first locate the fuse panel usually on a newer Ford it's on the side of the dash with a popout cover that says pull, check your fuses if the fuse is blown replace it once if it works from then on ok, but if it blows out again right away you will need to locate the short to ground keeping in mind that it could be the solenoid drawing too much current.
Oct 13, 2010 | 2000 Ford Taurus
Shifting in gear hard at time, 2004 ford taurus, this does not happen all the time
The brake switch for keeping the car from going into gear without pressing on the brake pedal might be going bad.
Jul 05, 2010 | 2004 Ford Taurus
96 ford taurus gear shift stuck in park
CHECK IF THE BRAKE LIGHT COME ON WHEN YOU HIT THE BRAKE PEDAL. IF DON'T. CHECK BRAKE LIGHT FUSE. COULD BE A BRAKE SWITCH. THERE IS A shift lock solenoid that receives a signal when the key is on and the brake pedal is depressed that allows you to move the shift lever to be taken out of park.
Mar 25, 2010 | 1996 Ford Taurus
I have a 1999 Ford Taurus SE. It is hard for me to takee the shift out of park when I first start the car. And when I do I have to press the brake really hard..
replace the brake light switch, thats where the power comes from to release shift lock soliniod, common problem,good luck.
Nov 01, 2009 | 1999 Ford Taurus
2000 Taurus starts just fine. Transmission stuck in park. Cannot shift. I do have foot on brakes.
When you push on the brake pedal with the ignition key in the run position, do you here or feel a clicking noise at the shifter?
There are also (2) fuses in the interior fuse box ( #17 and #32) that must be checked to make sure they are not blown. If the fuses are good, I would suspect either the brake switch or shift interlock solenoid.
The fuse supplies ignition voltage to the brake switch, when the brake is applied, the switch closes and voltage travels to the shift interlock solenoid. The solenoid is activated and the shift lever is unlocked.
So, it may be one of several things causing the problem.
1) blown fuse.
2) brake switch defective
3) shift inter lock solenoid defective.
4) wiring harness or connector problem.
Oct 09, 2009 | 2000 Ford Taurus
Having trouble getting a 96 ford taurus wagon out of park
theres i locking pin in there that is problyu going bad you will have to bent bake or replace it hope this helps
Sep 21, 2009 | 1996 Ford Taurus
Can't shift out of Park position
Take it back to the JACKASSES that fixed it, and tell THEM to FIX it!
Sep 10, 2009 | 1996 Ford Taurus
Can't get my 2000 ford taurus out of park
The gear selector is locked until the system detects the brake pedal is being pressed, the brake circuit then sends a signal to the shifter release solenoid to pull a pin back and let you shift out of park, this is a safety feature required by federal law, U need to have someone see if the brake lights go on when you press the pedal, if they don't check the switch at the top of the brake pedal, if the brake lights work then the little solenoid is defective.
Oct 15, 2008 | 2000 Ford Taurus
Scosche Industries Fd134030b 96+ Ford Taurus/Sable Kit Logo
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
