Question about Belkin ( F3U13306) (f3u133-06)
Shielded usb cable
We have a broblems with my sooft wear for shielded usb cable
  • 47 Answers
Pretty sure software has nothing to do with it...it might just be a bad cable. try plugging in some thing else. if that doesn't work, check the port and the peripheral you are trying to connect. also make sure you have installed the correct drivers.
hope this helps
Posted on Apr 10, 2008
What could be the cause of my m audio m track soundcard making inner noise like a radio is turned on
I have had a similar issue and discovered one of my audio cables wasn't properly shielded. Try a new set of cables including the USB cable. If there's bad shielding or ground on any of your cables it can pick up outside interference. Also, try each input cable one at a time to try to narrow down which cable or input it could be. If you get the interference with a new USB cable and nothing plugged into the unit there could be a bad ground in one of the XLR or 1/4" input.
Sep 22, 2014 | M-Audio MTRACK USB Audio Interface w/...
Tip
Problem Detecting a USB Hard drive or a USB Device If your computer or laptop...
If your computer or laptop has a problem detecting a USB hard drive or a USB device, and another computer can detect it, then the problem could be a RF interference problem.
Then this may help.
Try using an USB cable that is a shielded USB cable (ie. An USB cable that has a clear plastic covering and you can see a metallic weave which covers the wires) OR a USB cable that has a Ferrite core attached to the USB cable (the ferrite core is a cylindrical object approximately 30mm long X 15mm diameter and it is attached to the USB cable near the connector).
on May 19, 2011 | Televison & Video
2002 Jeep Liberty Sport with the 2.4L (manual Tran.) Speedometer stopped working, Check engine is on, and now it's stalling between shifting and at low rpm.
Speedometer cable may have broken. You can't tell from the outside of the cable, since it has a plastic shield. You have to disconnect it from the transmission to check it. If you can turn the cable inside the shield easily, it is broken.
Apr 30, 2012 | 2002 Jeep Liberty
My broblem is, i have a signal from in my broadband roater,but my computer canont get it the signal from my roater. please help me about this broblem.
Kindly check the configuration of your router and to your computer..probably it has a problema to their ip address, if not check the cables to the router and test your utp if you have cable tester so that we can check if the connection is okey to get a signal to your router to computer.
Sep 16, 2011 | Computers & Internet
Can't detect the usb drive, have noise
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Aug 18, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
Hard disk not found
May 30, 2011 | Western Digital My Passport Essential...
USB Device not recognized. Pl
May 23, 2011 | ASUS M2N-MX Motherboard
I havae panasonic KX MB 772, did i have to on its PC while installing its driver.... because when pc is on it demands for usb cable...when i connect the usb cable it doesn't detect....... plz send me...
Follow the on-screen instructions, do not use usb-extension cables. Try a new thick and short (well shielded) usb cable, connected it directly to the rear usb ports of your PC.
May 20, 2011 | Office Equipment & Supplies
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
CX9400 Windows 98???
Unfortunately, Windows 95, 98, and Me are not supported with this printer.
Listed below are the system requirements for your printer.
Windows Requirements
- A Microsoft Windows compatible PC with an 800MHz processor (1GHz or faster processor recommended)
- Microsoft Windows 2000, Windows XP, Windows XP Professional x64 Edition, or Windows Vista
- 256MB RAM for Windows 2000, Windows XP, and Windows XP Professional x64 Edition (512MB recommended) - 512MB RAM for Windows Vista (1GB recommended)
- 300MB free hard disk space (550MB recommended)
- 4x or faster CD-ROM drive for installing the software
- A Windows-compliant USB port and shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
- An Apple Macintosh with a PowerPC or Intel processor
- Macintosh OS X 10.2.8, 10.3.9 to 10.4.x or later
- 256MB RAM (512MB recommended)
- A USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
May 25, 2008 | Epson Stylus CX9400 Photo Printer
Belkin ( F3U13306) (f3u133-06) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
