Question about Maytag Washing Machines
What is the drum capacity of the LA 610 washing machine?
2 Suggested Answers
  • 91 Answers
SOURCE: why dose the water leak out from the Miele
Hi dear.Please check the door gasket for any wear & tear.(Also open the door,ajar inside the door gasket, check inside of it for any fine tear or cut.)Please check for pump filter.Is it attached correctly.I hope that helps.Thanks.
Posted on Sep 02, 2010
Wash Capacity WF810W
wash capacity?? what is the dry weight?? you meen
did you look at the manual ???
i see its a 7KG machine so 7KG DRY weight
wet weight LOL
what type of water and what did you put in the drum
so its a 7KG machine
so you can put in 7KG of matter to then get wet and get washed
Mar 05, 2015 | Whirlpool Washing Machines
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Is there a lint trap on the Maytag LA 610? If so, where is it? How do I clean it? Thank you. Karen
Hello Karen,
On that Maytag the lint screen fits into the top of the agitator and to clean it just pull it up and out,i am not talking about the softner dispenser cup but the part that cup fits into.
Gene
Aug 17, 2011 | Washing Machines
My ariston intergrated washing machine''s inner drum has dropped and is making alot of noise, it seems to be detached and ''loose'' from the outer drum casing
Either the main drum bearings have collpased, or the drum support has corroded and fractured, thus causing the drum to collapse.
It is a major repair, and quite expensive to put right.
In my experience. I think you would be well advised to consider replacing the washer.
Please rate my solution.
Thankyou.
Jan 24, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Purchase of washing machine
well...the hole less drum has more concentrated spin/wash water solubility. The hole drum has a more effective rinse release cycle. The holeless drums are usually used for higher weight loads, since the water penetration on those can be critical. Water capacity and usage are key to this choice. It all depends on the availability of clean water in your district.
Feb 10, 2008 | Washing Machines
Kenmore 3.1 capacity front load washer
CHECK REAR BEARING(rear of drum)OR THE ROLLERS THE DRUM ROTATE ON LOWER PART OF WAShER
Jan 19, 2008 | Kenmore 43142 Front Load Washer
Hotpoint aquarius
What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Apr 10, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
