Question about Lexmark X1150 All-In-One InkJet Printer
I have downloaded the drivers for the printer but when I go to print out it says the printer is offline and it just has the job sitting and no printing is happening.
  • 10,421 Answers
When I try to print I get the message " Printer
Check the following steps to fix printer offline error :
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 04, 2011 | Brother MFC-490cw All-In-One Inkjet...
Keeps showing offline even though I put in new cartridges and it cleans. When I test print, I have to do it manually and the paper comes out blank. When I check the ink status for some reason it shows...
First unplug your printer from the computer then uninstall you installed driver . After that plug it to the computer and install driver again. Then restrat your computer after successfully instalation. If still now ggive the problem then install driver from the below link and install it.
http://download.cnet.com/Brother-MFC-240C-USB/3000-2110_4-99329.html
hopefully it will be work. Other wise go to the servicing center.
May 04, 2011 | Computers & Internet
Printer is offline
Hi, turn it's power on. be sure the usb/data cable is connected to the cpu, if still not, remove the printer's adapter and connect it again, power it up again. if not still online, restart your pc.
When you want to print a document, you choose print and select your favorite printer but nothing happens. You look at the printer menu and see the pesky printer offline message and instant frustration. The task of the moment is going from offline to online. With creativity and patience, you'll have your printer back online in no time.
Instructions
Attempt to set the printer to online. This may not often work but it's the first action to take. Go to "Settings" and then "Printers". Right click on the "Printer" and select "Use Printer Online". Test the printer to see if it now prints.
Clear any print jobs. Double click on the "Printer" after performing the above step. Go to the "Printer Menu" and select "Cancel All Documents". There could have been a stuck print job that would cause the printer to go offline. Try once again to set the printer back online and try printing a test page.
Turn on the printer. Make sure the printer is turned on and turn it off, wait a minute and then turn it on again. Check to see if the is jammed. Check all the network connections to make sure none are loose. Repeat the above steps again if necessary.
Restart the computer. If this doesn't work, you will have to reinstall the drivers. Go to "Settings" then "Printers" and select the printer. Right click on the printer and choose "Properties". Under the "General" or "Details Tab" look for the driver button and select it and choose the driver again. You may also have to download the driver from the printer manufacturer website.
Reinstall the printer. Under "Printers" in the "Settings" menu, go back and select the printer, then delete the printer and reinstall the printer through the add printer wizard. Use the latest printer driver from the printer manufacturer's website.
Hope it helps.
Thanks for using fixya.......
Dec 06, 2010 | Epson Stylus NX100 InkJet Printer
Describe your hp business inkjet 1200 dn driver Problem I couldn't find an exact driver match for my iMac with OSX 10.6.4. Now it won't print on both sides and the tools don't work (such as cleaning the...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Inkjet 1200dn Printer
I have a HPC6280 Printer and cannot get it to print from my wireless printer with Windows 7. It keeps saying offline.
  • Connectivity :
Oct 26, 2010 | HP Office Equipment & Supplies
It is offline and will not print. Last print job
check the printer cable, try to change with other cable, or you can try to reinstall your printer driver.. hope these will help
May 04, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Samsung ML-2525W monochrome laser printer; connected via USB to MacBook Pro. Prt driver 1.00.02. First job prints fine; 2nd job in queue fails to print, and ''Open Print Queue'' indicates ''printer...
I have the same problem with mine - first job usually prints but no go on the second one. It tells me the printer is "offline". In some cases I can't even power cycle normally. I have to unplug the back cord and plug it back in, then I can power back on.
I called Samsung today 1-800-726-7864 and was told the printer will need to be taken to a repair center for service. Wish I had better news.
Apr 25, 2010 | Office Equipment & Supplies
Print status: error - offline what does this mean? I have a PSC 2355 all-in-one
Printer status offline means that, the printer driver and the application has been installed, but the printer and it spooler services are idle
To resolve this issue:
Goto control panel, click on printers and faxes, a window will open showing you all the printers you have or have had. The current printer will have a checked mark. Highlight it and right click, you will see printer offline in the box, click it. That will turn the printer online and you can print.
Dec 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Lexmark printer error messagenicating with the computer
The books for most printers are so useless to us they may as well be burnt. I get fed up with useless info. Very rarely of help. My first suggestion if you are running the correct driver for your OP, and your printer was previously fine, is to check if the printer queue is blocked up with too much memory from print jobs.
Go to the quick launch icon in task bar at bottom of your screen, right click on the printer icon, and bring up printer jobs window, scroll down to cancel print jobs. Now, once done, turn off your printer. Let it sit off to reset it. Turn it back on and try to reprint what you want. If this fails, you may have its preferences accidentally switched to work online or something else. Check it is not. My friends canon was accidentally set to this and it would only print off internet, and would not communiacte offline until we checked the work offline preference in the preferences collumn. Post back if no go. Cheers,
Feb 10, 2008 | Lexmark X1195 All-In-One Printer
Hp printer 5420 photosmart
sadone:
I assume all hardware connections are fine, and any lose cable connections are already checked then......
1)Send a test page to the printer Open up the print jobs, and try deleting all jobs (click on the printer from printer and faxes under control panel, delete all print jobs, Still in this window click printer and uncheck the print offline, does this help?) if not then
2)Try uninstalling and reinstalling the printer driver and then try printing a test page.
3)Try uninstalling and reinstalling the printer software and driver and then try printing a test page.
If nothing works then:
-Uninstall all printer software, driver unplug and reseat an original hp cartridge and go this link install software and driver and follow instructions on how to install the drivers, at the end click the check button to see if driver is fine. Now you should be able to print.
Dec 24, 2007 | Office Equipment & Supplies
Lexmark X1150 All-In-One InkJet Printer Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
