Question about Kenmore 57029 Side by Side Refrigerator
Ice machine will not dispense ice through front panel.
The actual model number is either 55251 or 56261
  • 1 more comment
  • pjcdenver Apr 26, 2010
    The ice is being made properly but the it appears that the auger that feeds the ice through to the door is not turning.??? When the switch is activated by the glass I can hear a humming noise but clearly the ice is not being feed to the drop through to the door...
  • pjcdenver Apr 28, 2010
    I will have that info soon. I did notice that another fridge w/icemaker that the " fork-like " mechanism that is apparently affixed to a motor or drive shaft and turns the auger assembly will spin with out the ice tray assembly in the fridge when the button is pushed to dispense ice. On my friend's fridge, the fork will not turn when the dispense button is pushed.. Could this be a motor issue and if so, can the motor be accessed through the rear panel of the fridge? I could send a rough sketch of the fork, if you'd like...
  • pjcdenver Apr 29, 2010
    I will try this on Saturday....will let you know.
    President:
  • 1,554 Answers
Check the ice bin for an ice jam and clear it. The motor is running as you can hear it hums. The couplings are dis-aligned causing the auger not turn or a gear inside the motor is broken.
Open the freezer door and remove the ice container then remove the two screws attaching the cover to the motor housing.
Remove screws securing the motor bracket and allow the motor to drop down. Press the ice dispenser button then check whether the drive shaft turns or not; if it does, hold the drive shaft and check it if it can be easily prevented from turning. Replace the motor if it hums but the drive shaft is not turning or if stops easily when held indicating that a gear is broken or the motor is just humming and not running at all.
Check the coupling if the motor turns out to be running fine and drives the shaft properly.
Posted on Apr 29, 2010
  • 619 Answers
Need the model number off the label inside the fresh food section. The number you have provided is not a correct or complete number. The label will have model and serial number both.
Posted on Apr 26, 2010
  • 821 Answers
Hello,Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
kindly check the water filter if it's in good shape if not it has to be replaced.
take care.
Posted on Apr 25, 2010
  • Hammid Disu Apr 27, 2010
    hello,i suspect it's the auger or the screw holding it that is producing the humming sound.so you will have to turn the screw AND ALSO TAKE OFF THE ice THAT GOT IT STUCKED.and also check if the water valve gets enough water that could allow it push to the door.kindly empty the ice tray yourself manually and you will notice that it till dispense ice from the front door.it's the ice that got stuck that did not allow the screw to turn well to allow it to dispense through the front door..
    you can as well visit the link below for a more comprehensive instruction...
    http://www.youtube.com/watch?v=oPAY2LsKV...
    OR
    http://www.youtube.com/watch?v=-EBiLyYXM...
    wish you good luck,
    TAKE CARE.
My GE monogram ice maker is dropping ice inside the freezer when dispensing
Reach your fingers up into the dispenser from the front and feel to see if the ice dispenser door is shutting all the way when it should be closed. Like my help? What is the model number of the fridge?
APPLIANCE 911
Apr 14, 2016 | GE Refrigerators
Drops ice without being called for
Is the machine dispensing ice just after the cup is removed in front of the hands free sensors? If so then you need to add MDT portion controlled dispensing kit. A time - delay relay kit is now available for addition to the MDT3,MDT4, MDT5 and MDT6. The purpose of the kit is to limit the amount of ice dispensed per activation. The kit number is KPC-MDT. The kit includes a time delay relay and potentiometer. When the touch-free dispense system is activated, the time relay powers the dispense motor and / or door solenoid for a limited time. That time is adjustable to accommodate the cup or glass being used. a typical application for the kit is a high volume dispense situation where the amount of ice spilled is unacceptable. Spilled ice is usually caused by overfilling the container during dispensing,followed by the extra ice being dumped into the units drip tray.Adding the kit allows the amount of ice per per dispense to be set to match the amount an individual needs,so there is less waste. This is especially helpful on the MDT6, which is a high volume,rapid dispensing model. Now if the machine is just dumping ice when no one is around it, then replace the hands free sensor.
Apr 14, 2014 | Scotsman MDT5N40A-1H 523 Lb Touchfree...
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
Ice maker not working water is coming out through the front for drinking but water does not seem to be going up the line for ice in the rear of the frig
On units with both ice and water dispensing there is what is called a dual fill valve. One side of the valve can go bad, which allows water to dispense but no water flows to the ice maker. Common problem. Just search for the part using your unit's model number.
Dec 01, 2009 | Washing Machines
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
Spring and Mechanism Delay fell out of ice dispenser
This is common, take your model number and go to the appliance parts store and order a ice chute dispenser repair kit.
Dec 25, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE Maker stuck in dispensing crushed Ice
That means that the evaporator fan system that releases the the ice cubes is not working.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 29, 2008 | Frigidaire GLRS267ZC Side by Side...
Ice Will not dispense
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.          http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=110&p_created=1147725595&p_sid=lTIkCMOi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEmcF9wcm9kcz0xOTkmcF9jYXRzPSZwX3B2PTEuMTk5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9d2F0ZXIgZGlzcGVuc29y&p_li=&p_topview=1
Oct 13, 2007 | Whirlpool GC5SHEXN Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
176 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
