Question about Apple iPod nano
Doesn't recognize playlists
I have reset my ipod and restored to factory settings, yet it doesn't recognize my playlists. The ipod PC version keeps creating a playlist from most of my songs. (815 songs) and won't recognize any other playlists. Also, I seem to be unable to create new playlists.
  • Apple Master
  • 13,433 Answers
Try uninstalling and then reinstalling the newest version of itunes.
drop me a line if you need more assistance.
Posted on Mar 25, 2008
My ipod got erased and now my computer won't recognize it
try to format it with your comp.it will erase everything but it will reset your ipod to its factory settings.if you need i a guide on formating it email me and i will write one for you.email=gamecrazy944@yahoo.com
Jun 30, 2009 | Apple iPod touch
Ipod connection in my lexus doesn t work...it freezes when in operation. Using usb and accessory ear plug...
I would reset the ipod and make sure that the connection isn't being jostled at all. That could cause the symptoms you are describing. Other then that it should work fine. However, if after a reset you are still having the same issues; I would restore the ipod using itunes. Below i have posted a step by step on how to do both just in case you haven't had to do them before.
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Also I would make sure that there is no short in the usb cable you are using.
May 03, 2009 | Apple iPod classic MP3 Player
Ipod 20gb click not recognized by windows
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time. :) Let me know if this does not resolve your connection issues
Apr 29, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Ipod skips over many songs then freezes
Here is a helpful article from apple on learning how to reset your ipod.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
If you still have issues after doing a reset you will need to restore the ipod using itunes and just in case you are unfamiliar with how to do that here is the instructions as well.
How to restore iPod (ARTICLE NUMBER HT1339) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install the latest version of iTunes if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
I hope these steps resolve your issue good luck. :) CHEERS
Apr 23, 2009 | Apple iPod nano 3rd Generation
Want to reset
To change the language on it, you will have to restore it back to factory settings, which will delete everything off, and when you turn it on, it will show up on a screen where you will select the new language. Then, to make it sync only the playlist that you want on there, go to the ipod's main menu (where you can click on the restore button also) and click manually manage files. It will ask you if you are sure and click yes. After that, click and drag the playlist you want on your ipod to the ipod icon and the playlist and its music only will be on the ipod.
Mar 11, 2009 | Apple iPod nano
Cant get songs onto ipod shuffle.(daughter has ipod touch)
When you go into the ipod section on iTunes, click the music tab, make sure 'sync music' is checked and 'selected playlists:' is also, then check the playlist you want to use. Click 'sync' button
If that don't work go back to the summary tab and hit 'restore' and follow the instructions to reset the ipod, resync and all should be fine.
All the best
Sean
PiDigital
Dec 31, 2008 | Apple iPod shuffle Second Gen. Silver (1...
New Ipod Shuffle is not loading songs
Generally you do not have to change the drive letter. There is a 'shuffle restore' program from Apple that you can download for free. Using this to restore your iPod will set it back to factory conditions. Do you have the latest version of iTunes on your computer? If not, you might want to try that also. Have you tried dragging your playlist into the Shuffle? I find that it helps with my shuffle to create playlists and have it fill out of them. That way I can change the playlist every day. Works for me. Hope that helps.
Dec 23, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Cannot locate music
Plug your Ipod into your computer and load up Itunes. Select restore Ipod to factory settings under Itunes. This will reset your Ipod and allow you to reload the songs.
Nov 18, 2008 | Apple iPod MP3 Player
Ipod
First I would suggest you make sure the iPod is connected correctly, and that you wait until the iPod has finished updating.
If you are sure of that, you can always restore the iPod to it's original settings.
(I would also suggest that you are using the most updated version of iTunes)
But before you restore your iPod, there are a few steps you can take to try and fix this problem.
If you can’t download a song or other item to iPod nano
The song might have been encoded in a format that iPod nano doesn’t support. The
following audio file formats are supported by iPod nano. These include formats for
audiobooks and podcasting:
 AAC (M4A, M4B, M4P) (up to 320 Kbps)
 Apple Lossless (a high-quality compressed format)
 MP3 (up to 320 Kbps)
 MP3 Variable Bit Rate (VBR)
 WAV
The most common is to reset the iPod. To do this:
  •  toggle the Hold switch on and off ( Set it to hold then turn it off again)
  • Then press and hold the Center and Menu buttons for at least 6 seconds untill the Apple logo appears.
If this does not work I would consider restoring. This means you will loose all your music,pictures, videos..ect. But from it sounds, you don't have anything on your iPod to loose.
update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
Apr 09, 2008 | Apple iPod nano
IPOD ? playlist backup
If your IPOD is set to automatic song transfer, and you created an ?on the go? playlist, the IPOD will automatically transfer all songs along with the playlist. I haven?t tried the following myself yet, but this is the only way that I can think of: Cancel the auto transfer option ? from the source list in itunes choose the iPod icon and press on the options button. Choose ?manually manage songs and playlists? If it doesn?t work then I guess its more of a one directional thing, that you get more options going from the PC to the iPod then the other way around.
Feb 21, 2006 | Apple iPod MP3 Player
Apple iPod nano Logo
70 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
