Question about Insignia IS-DVD1001 DVD Recorder/VCR
Tape gets stuck
Vcr tape won't come out. It gets "eaten."
    Sniper:
  • 52 Answers
It sounds as though the tape player mechanism isn't working correctly. Either the machine's tape heads are't engaging fully, but usually this is a result of the drive belts becoming worn and not turning one of the tape reel's at the same speed as the other. Culminating in a difference so one reel will run faster than the other, this can cause bunching of the tape as it goes through the tape heads jamming it up. The VCR will need to be inspected by a technician for repair or replacement of the drive belts.
Hope this helps,
James
Posted on Apr 25, 2010
Why does my vcr always eject as soon as I put a tape in, getting the tape stuck in the machine in the process?
wow a vcr im going to bet this one is ten + years old , as with any item that has ten + year old rubber parts inside it , this id say is your problem as the eaten tape is the tip off for this as a tape drive problem
Oct 30, 2015 | Sylvania DVC840F
I experience problems with my VCR. A tape got stuck. After I removed the tape, it comes up with an error message F03
If you have children who can access the machine, unplug it, turn it upside down and listen for any rattles or loose bits inside. Kids are notorious for 'posting' coins, half eaten snacks and the like into the 'letter box'. Any loose objects, particularly metal, MUST be removed before switching on again. If a tape has become damaged, bits left inside the machine, it will have to opened up to remove the debris and ensure that the tape transport path including all rollers etc are cleared.
Jul 04, 2014 | Panasonic Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
I have a Phillips combo dvd/vcr - all of a sudden when I put a VCR tape in, the word ERR is displayed and tape won't play. It has now eaten 1 tape.
Most likely the mode switch in the VCR has either gone high resistance, and will need to be replaced, or it is probably dirty, thus it can be cleaned using electronic cleaner (assuming the mode switch is a rotary type encapsulated in a plastic casing (some VCRs incorporated a sliding mode switch - such as National in the early 1980s) - a spray cleaner/lubricant may do the job - not expensive - this cleaner should be available from most leading electronics/hobby stores off the shelf).
The downside is the cleaning of the switch (which should be under the VCR mechanism and soldered to the motherboard) cannot guarantee long-term reliability, so the switch will have to be replaced (this could be tricky being Philips/Magnavox) - but try cleaning it first - this is cheaper and you don't go without a unit for a long time. I hope there are no tapes stuck inside the unit.
In this case, I strongly recommend that you try and clean the mode switch with electronic switch cleaner - it comes in an aerosol spray can and is not expensive. You may need to look around for the appropriate type of cleaner as there is more than one available. CRC is the best bet according to technicians. CRC is a spray electronic cleaner/lubricant - so it will also lubricate the switch contacts as well as clean and remove oxides. Do not use supermarket sprays such as WD-40, or automotive sprays such as ArmorAll.
I do not recommend removal and disassembly of the switch itself to clean it unless you are tech. savvy with several years' experience, and you have some understanding of its alignment in relation to the mechanism. If you are careful, and with the unit unplugged from the wall, you can remove the VCR deck to gain access to the switch on the board and carefully apply the abovementioned cleaner, rotating the switch in both directions gently, to work the cleaner into its contacts. Let it sit for a few minutes, then re-fit the VCR deck, and reassemble the rest of the unit. Plug into power, and test a tape. This simple method should work (you won't need to remove the motherboard to do this, just the front panel and VCR deck) and it only cost you a can or two of contact cleaner at most.
You should not need a new unit.
Jun 19, 2011 | Philips DVD750VR DVD Player/VCR
Vcr is eating the tapes
THE VCR NEEDS REPAIRING.THE REASON WHY YOUR TAPE IS EATEN THE TAPE PATH NEEDS RE- ALIGHNMENT AND LUBICATED AS THE HEAT FROM THE TV WOULD OF DRIED THIS OUT.
May 02, 2010 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
My vcr/dvd recorder eats the tapes.
clean pinch rollers and head. check if there is any dirt on capstan post
Apr 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Video tape gets eaten on rewind
Does the machine play tapes well? Clear steady picture and all? No tracking bars? wavering sound? Tape chewing is generally a problem with a bad Capstan Pinch Roller, Associated symptoms are as above. Please do recheck or confirm if any of the above problems are also present.
Aug 30, 2006 | JVC HR-VP650 VHS VCR
Eaten tape
Can?t help you with the price, but it sounds as if the problem is a loose pin that might have gotten loose in the eaten tape incident. Maybe you should get a second opinion.
Feb 22, 2006 | JVC HR-J461MS VHS VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
113 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
