Question about Delta & Single Handle Shower Faucet
I hook up everything ,but i only gey hot running
Vessona bath fixture--has a cartridge thats installed into the main unit,when i install it iand turn it oni get just hot no cold --i check the cartridge a well as replacing after 5 times with no solution.. when i remove the cartridge and turn the water on i get streams of hot and coldd
any suggestions?
  • 6,674 Answers
Have you tried removing cartridge, rotating cartridge 180 degrees then re-install?
Posted on May 02, 2010
Newly installed Price Pfister single valve knob is hard to turn on and hard to shut off.
Is newly installed a phrase for under 6 months? If this is a faucet that is about 3 months old, it could either be hard water (possible debris) or a control valve failure. I would suggest you turn it in for a warranty correction. If that is not an option, your best bet is to shut off the hot and cold water underneath the sink, remove the handle and dismantle down to the valve cartridge. Remove and replace the cartridge. If this fixes it, make a written note as to when it was done. If the problem returns again in a short time, it's something coming through your water and will continue to give you grief. In that case, buy a two handle faucet and forget the fancy fixture.
Nimsgame
Feb 14, 2011 | Price Pfister Single HDL Bath Faucet...
The hot water is not coming out the tap in the bath,only slight dribble,it wont turn on fully also.
possibly some sediment caught in the cartridge or stem. put some water in a bowl or sink, turn the water off to the fixture, remove the cartridge or stem, flush the cartridge or stem in the water, check for blockage inside valve body, replace parts, turn on water.
Dec 05, 2010 | Home
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
I have red, metal, beige, and black wires in my ceiling. how do i hook up my Glendale fan?
If you could give me the specs on this (voltage and amperage), I can begin to help. Also, I would need to know what the values of the wires in the ceiling are. Meaning...is Black or Red wire's a Hot wire or switch leg. To find this out. First turn off the circuit breaker(s) at your electrical house panel. There could be two circuits, so make sure to have a voltage tester, or a little induction voltage tester that will help determine if power is on or off. Also, turn your wall switch off designated for this fixture. Now, leaving the wall switch off. Make sure to do this with two people. Turn on the circuit breaker. Either the black or the red wire will be hot (unless there's other circuits involved, which I don't think there is). Once you determine your hot wire, write it down. And then turn on the wall switch. Now, the other wire should be hot now. This is your switch leg. The wire that will operate (on and off) your fixture. Beige is most likely your neutral wire, and will go to the white wire(s) at the fixture. And the metal wire is your ground wire, and should go to your bare copper wire inside of your fixture. So now, turn everything back off (including both your circuit breaker and wall switch). So, Hot wire goes directly to your wall switch. It might be easier to hook up your switch leg first, because then the wire left over will go to your switch. So, Hot wire hooks up to wall switch. Other wire coming from switch, hooks up to the other colored wire (switch leg). The beige wire stays at the fixture and hooks up to the white wire(s), and then the bare copper wire splices (connects) to the metal wire from the ceiling. After you have everything wired, and the fixture put back together. Here's how you test it. Leave wall switch in off position. First, turn the circuit breaker back on. If everything is fine, then you turn on the wall switch. Note: If you're able to leave the fixture in the on position prior to turning the wall switch on - do so. That's why if there's any problems, you'll be a safe distance away. And the worst that could happen is that you trip the circuit breaker. Then, you'll have to recheck everything you did, and make sure all your connections are secure. Well, Good Luck to you, and feel free to ask me any further questions you may have. Jim
Jan 22, 2010 | Hampton Bay 52 In.Carriage House II in...
Takes too long for hot water.
You need a recirculating line. You will have to hire a plumber to run a water line from the farthest fixture or to the fixture you are concerned about on the hot side and return it back to the water heater. this will cause hot water to constantly run throught the hot water line (via the recirculating line) and when you want to draw water from the fixture, you will already have hot water right at the line.
I know this works with standard tank water heaters, but it is a lil trickier with rinnai units(but very possible) if your plumber pleads the 5th and tries to sell you another unit call the Rinnai manufacturerand ask them how.
Jun 12, 2009 | Rinnai Water Heaters
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Unit not working - don't know how to remove
the unit willnot effect any water delivery anywhere in your house.
Mar 03, 2009 | Thermasol Steamshower Generator AF Series...
Single handle moen bath fixture only lets out hot water
remove the cartridge and see if their is anything blocking the cold inlet.If you dont see any dirt than that means that the cartridge needs to be replaced
Jan 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Delta & Single Handle Shower Faucet  Logo
122 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
