Question about Maytag Washing Machines
Water is trickling out and takes over two hours to fill. Is there a water sensor that may have gone bad?
    President:
  • 1,430 Answers
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Apr 25, 2010
MY MAYTAG FRONT LOAD AT TIME WILL FILL WHEN WASHER IS NOT ON OR WILL DRAIN AND SPIN ON IT'S OWN
It may be the water inlet valve is not shutting off the flow 100%. If water keeps trickling in, even dripping, it will eventually fill the drum. Some models have a water level sensor that will run unit thru a drain cycle to prevent an overflow situation. Try checking the unit every 6 or 8 hours to see if there is a slow build up of water accumulation. Replace inlet valve if there is.
Dec 26, 2014 | Maytag Washing Machines
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Water trickles out when filling instead of the steady stream
Check the water inlet valve. Remove the water supply hoses and check the small metal screens inside the valve (especially the hot water side) and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. Here is a photo for reference. Hope this helped and best wishes.
Sep 30, 2009 | Kenmore 23822 Top Load Washer
Washer will barely fill with water for the rinse cycle it can take several hours.
hi..the reason to this problem is the pressure hose,
it might have got clogged.
check this out..
thank you..
kindly rate my response..
Jul 19, 2009 | Kenmore 22422 Top Load Washer
The cold water trickles out and it takes a hour to fill the tub. someone said the delay switch but where is it?
check your water supply lines. there is a small screen filter where the hose from the tap or other water supply line enters the machine. it may be dirty from mineral build up. make sure all is clean , both ends.
Jun 14, 2009 | Washing Machines
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
F&p washing machine
Replace the dual inlet water valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
