Question about Dell (04U621) for Latitude D600, Inspiron 600M Motherboard
Battery will not hold charge ..got new battery lasted 1 month and shorts out the charger
    Habit-Forming:
  • 24 Answers
I would open it and look to see if the DC jack is damaged. It could be arcing to another connection.
Posted on Apr 29, 2010
Batteries not charging for a couple of months now, place battery in charger it clicks and light goes off but dosn't charge?
Either the charger has a winding in the transformer short out or the battery lost its ability to accept and hold a charge.
Mar 19, 2015 | Health & Beauty
Why doesn't my s4 hold a charge?
It's your charger, it may have a shortage in it. Replace it and you should be fine.
May 28, 2014 | Samsung GALAXY S4
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Ilet chair set for 4 month is the battery still good
With power wheelchairs letting the batteries sit for 4 months without charging them leads to early battery death. The lead plates inside the battery sulfate over time and the battery discharges. If the batteries were fairly new (less than 1 year) before they sat for 4 months they can be resurrected and recharged but may not hold a charge very well. Distance traveled will be very reduced. You can try removing the dead batteries from the wheelchair and charge each individually with a 12 volt battery charger set to deep cycle. You will be able to see if the batteries come back up to full charge and do not burn. They cannot be recharged easily or safely inside the equipment and the charger that came with your equipment will not turn on. They should be removed from the wheelchair first. If the batteries take a charge and the PWC runs plan on using your power chair charger on them for at least 12 to 20 hours to bring the charge back up. Test the batteries over a short distance so you don't get stuck far from home. If you don't get very far before the batteries quit, invest in some new ones. Hope this helps.
Nov 13, 2010 | Health & Beauty
Will not hold a charge
Time for battery replacement!
Nov 05, 2009 | 2001 Yamaha V Star 1100 Classic
The batteries does not hold the charge.
A few solutions for you:
1) The batteries that you are using may have reached their end of life.
2) You are using higher capacity batteries in a charger that was designed for lower capacity batteries. The charger may be a 1 hour charger that was designed for say, 1500 mAH. If your batteries are 2000 mAH, then after the same hour, the batteries may not have a full charge, and will be damaged if this were the case, and the practice continues.
3) You are using a combination of batteries and charger that isn't compatible. For example, NiCD chargers cannot charge (usually) NiMH batteries, and vice versa.
4) There is always some drain by the batteries themselves, just being rechargeables. Though, this is usually on the order of 5-10% per month, and probably is not the issue.
I would put my money on saying that the batteries are worn out. Try a new a new charger / battery combination. If that works, then either the old batteries or old charger are defective.
Sep 15, 2009 | Canon PowerShot A590 IS Digital Camera
My battery is not charging and i just replaced charger
There is probaly a loose connection from the input for the charger.
but sometimes thats not the problem.
This happenned to me before , and I just called the company that made the laptop, and they said to just buy a new battery instead of going through the trouble of trying to repair it, which would take about 15-$ and 2 weeks. I would just buy a new battery for about 30$.
Feb 23, 2009 | Gateway M305CRV Notebook
Motorola W315
(If you are charging you phone inside your house) First make sure you have power to the receptacle you are using. test this by plugging in a lamp or radio into the receptacle you will be using.
I own the same phone and I have found that the phone has a small rubber cover that goes over the charging port. It's hinged but I found that it has to be removed in order to charge it because the charger can't connect securely with the rubber cover on the phone.
(If your are using a mobile charger) I have observed that my phone has a short in the mobile charger also and changes the ring tone after I charge it. My phone rings 1/2 of the time and I have found that this is a fault of the mobile phone charger. It charges the phone w/o any problem but the connection from the mobile charger is loose. This shorts out something inside the phone and changes my ring tone automatically.
Feb 11, 2008 | Motorola Mobility W315 Cellular Phone
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
