Question about Sony Cyber-Shot DSC-P92 Digital Camera
My memory stick does not have a lock or unlock position.
It is a Lexar 4GB magicgate memory stick pro duo
when I download pics to my computer it says it cannot erase because it is read only. Where do I put tape when there is no lock or unlock on the memory stick
    Brigadier General:
  • 11,967 Answers
Do not use the computer to erase a memory stick. If your pics are safely on the computer and you want to completely erase the stick, use the format function in the camera.
Posted on Apr 25, 2010
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
The disk is write protected
You only can use Memory Stick Duo. There is a write protection switch on the memory card, you only can switch with a sharp point. Ball point or something like that. Have a close look on the card.
"Memory Stick Duo", "MagicGate Memory Stick Duo" and "Memory Stick PRO Duo" are equipped with MagicGate functions.
MagicGate is copyright protection technology that uses encryption technology. Data recording/playback that requires MagicGate
functions cannot be performed with this camera.
So if you have a MagicGate one it does not work and could give this error.
Nov 06, 2013 | Sony Cyber-shot DSC-W50 Digital Camera
Memory card says full after just a few pics
You can check it in Windows by right clicking My Computer amd checking Disk Management. Look for partitions.
Dec 24, 2012 | Sony 4GB Memory Stick PRO Duo Memory Card
My 4gb memory stick pro duo didnt work on sony vaio vpcw21eag card reader magicgate hg duo.. pls help me... my operation system win 7 ultimate.. help me...
if your 4gb memory stick are not working,i suggest format your 4gb memory stick and use. step for format it , Right click on my computer and click on manage after open manage window click on Disk management tab after few second your 4gb memory stick are display it, right click on 4gb memory stick and format, select quick format , ok after few second complete format message are display , click ok and use your 4gb memory stick.
Jun 22, 2011 | Computers & Internet
Magicgate pro duo stick not recognised by computer. Aaagh lost holiday pics.
Send it to data recovery experts if you REALLY want those pics. no other option
Mar 10, 2011 | Sony Electronics - Others
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
SanDisk memory stick pro duo 4GB not reading
does ur camera recognize ur mem stick if yes then copy all ur pics to a computer then format it an insert the stick to ur cam and u can copu it again to the stick. check it out.
Oct 13, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
Misfunctioning 4GB memory stick pro duo
Are you formatting it with your computer or PSP?
  1. Push the little HOME button on the bottom left of the face of the unit.
  2. Use the arrow keys to move to the SETTINGS area, then move the up and down keys until you get to System Settings.
  3. Once you are there, click on the "X" button and scroll up and down as needed to find Format Memory Stick. Click on "X" again to select that option.
  4. The Sony PSP will now confirm that you want to reformat the memory stick (which removes every file and game save thereon, of course): choose yes and it'll format in just a few seconds.
It that doesn't work - try formatting it with your computer.
Jul 09, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
My memorycard is locked and it wont work in my psp
check to see if the tab on the memory card is set to lock. You should be able to move it back to the unlock position.
Jun 15, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Clie T615 not reading memory stick
Either the stick is defective or the wrong format.
May 04, 2017 | Sony CLIE PEG-NX60 Handheld
Sony Cyber-Shot DSC-P92 Digital Camera Logo
154 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
