Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
I can not put a desired event on recording thru"create timer"scre
I can not put a desired event on a recoring thru "create timer" screen. The only way, how I can record any event is to put recoring by using nual user stop". Also I lost all recorded events from DVR memory. Any solutions, what is going on? I already rebooted the system couple of times. Thanks in advance.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Aparfenov
The receiver hard drive is comparable to a computer hard drive. When a problem is detected with the hard drive, the receiver will give an error message stating a problem has been detected. Depending on the severity of the problem, sometimes it will show that unplugging the receiver for 1 minute will resolve the issue. Other times, a message will state that the hard drives needs to be reformatted, which will erase all content on the hard drive. It sounds like this is what happened to your recordings. If unplugging the receiver did not resolve the issue, we may need to replace the receiver. Please call 1-800-333-3474 and speak to a Technical Support agent.
Ray Calo
DISH Network
Posted on Jan 21, 2011
I'm trying to record somthing . I have deleated
There are too many things scheduled to be recorded, not that the storage space is full. Check the recording timers in the menu and try to remove a show or movie from the list and try again.
Sep 19, 2014 | Televison & Video
Can I recored a VCR to the DVD on this machine?without a TV?
yes, but I strongly suggest you use the screen (unless the recording is a 5 - 6 hour epic) where as you record the event and go to sleep and the devices shut off once finish.
Mar 16, 2011 | Broksonic DRVCR900 DVD Recorder/VCR
When I try to record back to back programs on different channels the timers won't work. It tells me there is a conflict with the timers and tells me to change priority or whatever. I can set a manual...
Hi this is Luke.
DVR Priority settings are used to prioritize timers should there be a conflict between timers. The top of the list is the highest priority and takes precedence. The bottom of the list is the lowest priority. A lower priority timer will not fire if there is a higher priority timer at the same time. Timers that conflict with each other will display Attention 532. The message may display when switching from Single User Mode to Dual User Mode because the receiver recalculates timers for conflicts.
  1. Press DVR three times on the remote (twice for a 942 receiver). The skip timer icon (red x) designates a conflicting timer.
  2. Select Timers.
  3. Select Set Priority.
  4. Select the timer to change.
  5. Use the Up and Down arrow buttons on the remote or the Move Up and Move Down options on the screen to move the timer priority one at a time. Use the Move to Top and Move to Last options on the screen to make the timer top or last priority.
  6. Select Done.
Selecting Automatically resolve by priority will allow the receiver to set the priority level of the timer. The last timer created will have the lowest priority level and will not be recorded if both tuners are being used for other higher priority level timers.
Selecting Change the priority of this timer will allow the customer to set the priority level of the timer. With the new event highlighted in the Daily Schedule screen (the event will display with the skip icon), press Select. Select Restore and then Yes. The new timer will now have a higher priority level than the conflicting timers.
You may also want to resolve the conflict by:
  1. Press Menu on the remote.
  2. Select Daily Schedule.
  3. Select Timers.
  4. Arrow over and select the timer that needs to be edited.
  5. Select Edit.
  6. Make the desired changes then select done.
Let me know if this help.
Jan 21, 2011 | DISH Network DVR 510 DTV Receiver /...
Dish DVR recording shows that haven't been programmed to record
This may be caused by as many as three variables.
The first would be that if your neighbor has Dish Network and they have their TV2 near yours it could be picking up their recording preferences. This would create a recording specific to let's say MONSTER TRUCKS.
The next is if you notice MONSTER TRUCKS when trying to view an intended recording at the beginniong or end of the desired recording. This can occur if the start time an end time for your recordings have been set to begin before your intended recording and end after the intended program completed. You can edit this by pressing the DVR button, my recordings, schedule, timers, pick a recording from the list and press select, now press options and you will see the timer options which will allow you to manipulate the start early time and end late time among other things.
Lastly is that your program guide is out of date or the guide is totally errant. Unplug the receiver from the wall for a minute and repower it. This will force the system to update itself if it is not intefered with during this process. If after this procedure the same issue is occurring and the guide says the program you want recorded but retrurns an unwanted one then the guide is corrupted on the Dish Network side and will be repaired as soon as possible.
I hope this assists you. Thanks fornusing Fix Ya.
Jun 20, 2010 | DISH Network ViP722 DTV Receiver /...
Dvr is programmed but at times "chooses" not to record show and other times it does record
Be sure that a DVR timer is set to fire, instead of an auto tune. Also if it is a series then make sure you select new episodes, your dvr will not recor a program if it has already recorded the same program once, ( re run) you can also check your scehdule in your dvr to check if timer has been deleted or modified.
Nov 13, 2009 | DISH Network DVR 510 DTV Receiver /...
Timer light flashing,
You have a record event set for your VCR. Consult your user manual for specific ways to delete.
Generally, if you still have the remote, you can press the menu button, goto timer / record setup and see what events have already been saved. There may be information on the screen indicating how to delete.
Aug 29, 2009 | RCA Televison & Video
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
Toshiba DVD/VCR Recorder
The only thing you can do is to program the recorder to come on and record at a certain time and also program the event timer for the Bell Expressvu.
Mar 13, 2008 | Televison & Video
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
112 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
