Question about Kenmore 19233 Computerized Sewing Machine
I have a SEARS SENSOR SEW 70. PROBLEM-IT WILL ONLY GO IN REVERSE. HOW CAN I FIX THIS? I HAVE OILED AND CLEANED. IT HAS NOT BEEN USED IN MANY MANY YEARS. BUT WAS STORED IN A CASE. THE MODEL IS 19501 JILL
  • 1 more comment
  • jillmarie907 Apr 25, 2010
    Sorry I have tried that with no change. It is still going in reverse Jill
    Okay- I did find a needle in the machine last week when i cleaned it. The bar that you mentioned --is this the one that moves the wheel?? Is timing the machine difficult? How would I do this?? I hope I am not in over my head. Thank you Jill
    Okay I finally have the bottom off. Located the rod. Could you tell me how to loosen it?? Sorry to be such a pain. Jill
    President:
  • 1,194 Answers
Thanks for using Fixya.
I suspect a control board might have failed in your sewing machine, due to which it is going in reverse mode. This repair should be done by a technician.
I recommend you take the sewing machine to a Sears Parts and Service Center or a Sears Retail Store for repair.
Good Luck and have a nice day.
Posted on Apr 26, 2010
  • 821 Answers
Hello,kindly push the reverse botton and it will start to sew forward...
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
thank you for using fixya,you are highly appreciated...
take care.
Posted on Apr 25, 2010
  • Hammid Disu Apr 25, 2010
    HELLO,KINDLY CHECK IF you will find the piece of a broken needle underneath the metal plate where the needle
    goes down to sew.If this is removed, it will sew both forward and backward.
    OR
    Open the bottom of the machine. There is a rod running from one end to
    the other. It needs to be loosened and turned 180 degrees. You may have
    to re-time the machine when you are done
    TAKE CARE.
    hello,kindly visit your user guide it is stated there on how to re-time your machine...
    take care.
My machine has not been used since 2004 and is stuck in reverse How do I fix this?
If it is a mechanical (NOT computerized) sewing machine, it most likely needs a good cleaning and oiling after not being used since 2004. Mechanical sewing machines need to be cleaned & oiled every time a bobbin is changed, every 8 hours of constant sewing, or every six months when not in regular use. Use only good quality sewing machine oil (NOT stale old oil, 3-in-1, WD-40, or cooking oil) and oil only 1 or 2 drops each spot as directed in the owner's manual.
Sewing machine oil tends to degrade over time and will eventually glue moving parts together. Keeping it maintained is a simple way of insuring it will work the next time it is used.
Sep 12, 2015 | Sewing Machines
Necchi 535FA is stuck in reverse, no matter what adjustments I change. I oiled and cleaned it and properly threaded it. Everything seems to work and move fine, except the reverse button was stuck.
A part of the Reverse Button mechanism is probably frozen.
This may work:
Direct heated air from a handheld hairdryer into the internal mechanism and let the metal parts get pretty hot. (Don't burn your fingers!) Then try the reverse button to see if it has loosened. Repeat and hopefully it will begin working. If you figure out where the reverse button mechanism is located, you can try lubricating the metal joints--ONLY 1-2 drops of GOOD quality sewing machine oil (do NOT use 3-in-1, WD-40, cooking oil, or OLD sewing machine oil). Then try the hairdryer again. Do NOT oil plastic parts or belts unless directed to in the owner's manual instructions.
Vintage Sewing Machines
To keep your machine sewing well, be sure to clean and oil on a regular basis--about every 8-12 hours of continuous sewing, every time you empty a bobbin, or if it's not in frequent use, every six months. Oil drying out is a frequent cause of machine moving parts freezing.
Sep 01, 2015 | Sewing Machines
How old is my sears Kenmore sensor sew 70 model# 3851950180? Iwould like to know if it can be repaired
Almost any machine CAN be repaired, but it may not be worth the money to get it repaired and with older machines finding parts can be a real problem.
If you call Sears and tell them the model and serial number they should be able to tell you the age of the machine, and whether or not they are still willing to repair a machine like it. They may not have parts though.. sometimes independent repair shops are a better bet. Ebay is often a good source for old machine parts too.
Nov 18, 2014 | Kenmore Sewing Machines
How do I fix a sewing machine that will only go in reverse?
Is the reverse switch stuck ? Sometimes they get a lot of gunk around them that sort of builds up and stops them moving, and it may be on the inside, rather than where it's easy to see. Might try to use something very slender, maybe a nail file or toothpick to see if you can remove anything from around the switch. Maybe a wee drop of penetrating oil may help dissolve any gunk that's stuck around it, but put a towel under to catch any that leaks through. If possible, remove the screws in the machine body to see if you can remove the exterior casing and get at the underside of the switch. If the switch appears to be ok, I think you'll need a repair shop.
When you say it was cleaned, do you mean on the outside, maybe the bobbin case, or did you have it serviced, where someone removed the casing and cleaned and oiled the entire working assembly inside ? If so, did they guarantee the work ? Most shops give you at least a month on their repairs, but that might not be any help by now and believe me I know how expensive it can be to get repairs done.
Do you have the model number ? Sears used to be pretty good at repairing their machines but they're not as good as they used to be, I'm afraid. But Kenmore is a common brand and most repair shops should be able to mend them unless it's a part they can't get hold of. Ebay can be a good source for parts like that.
Oct 08, 2014 | Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
My sears roebuck mo. # 148.12500 will only sew in reverse. How do I fix this?
Is it possible this machine has not been oil in quite a while and therefore, the old oil is turning into a varnish and seizing up the reverse slide mechanism? If this is the case, the machine will need to be serviced to clean the solidifying oil from the points of lubrication and re-oiled to make it work like new again.
<Ray>
Nov 08, 2010 | Kenmore Sewing Machines
Sears model 13 kenmore won't sew forward
its not easy sewing left handed is it? i think that oil has got into the switch and you have lost forwards drive now,,give it a good wiggel about till it clears it out, if it was working ok the last time you used it its just got a bit sticky thats all,,,i hope you used a light oil?
Oct 24, 2009 | Kenmore 12102
I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Kenmore 19233 Computerized Sewing Machine Logo
143 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
