Question about Mtd Bronco Rear Tine Tiller
I have a B&S 5.5 hp model 137202. It ran fine
I have a B&S 5.5 hp model 137202. It ran fine last year, but needed a coil. I replaced the coil. It starts fine on choke, but when moving the throttle to any other position, it races wide open so I have to kill it. Any ideas on what is happened or happening? Thank you.
3 Suggested Answers
  • 190 Answers
SOURCE: the tiller starts but will not stay running after a few minutes
that's a B&S 5hp motor
need a fuel diaphram most hardware stores carry small kits for small engines
manual page 65
Posted on Mar 22, 2009
  • 6 Answers
SOURCE: will only start and run in choked position, when
i have your solution guaranteed, I fixed mine yesturday remove H L screw plastic caps and on high 11 threads exposed and on the low side 8 threads exposed. removing the plastic caps allows u further adjusting these wear out or move soo just take them things off and you will be rolling
Posted on Apr 20, 2011
Testimonial: " Thanks, I removed both needle valve stems, cleaned and sprayed out seats with carb cleaner. Reset at 1 turn out from fully closed position. "
Knocking noise about every hour or so,lasts 5 or 10 sec's. just started after 7 years .
This is the first sign of the compressor going out. You will either need to replace the compressor or purchase a new unit.
Oct 22, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Will machine read misfire codes if converter is bad
No machine or computer is involved
What you need is to have a professional
scan tool hooked to the connector under dash
Then the answer is yes,in the correct Mode, the scanner
software will be able to see each cylinder & any misfire
counts.
Then you can replace, just the bad & well known & long history
of failed Ford COP Ignition Coils
If you play with a code reader, you will chase your tail & eventually
get the bad coils, finding them the hard way. That being, walking
a new coil from one cylinder to the next.
The converter should not be bad from 2003 to now
It should last 12 to 14 years, unless the truck ran poorly
for 5 years in a row & ruined it.
You should have changed the front (2 only) O2 Sensors
long ago at 100,000 miles. The rear monitors stay until they fail
Jun 03, 2012 | 2003 Ford Expedition
Honda 5 HP OHC Engine
did mice chew threw the wires to the coil over the winter pull the cover and look
Apr 07, 2012 | ALL POWER AMERICA LLC AllPower America...
Hi , was working fine last year but now is now
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 05, 2011 | Danby DDR5009EE Dehumidifier
The dehumidifier runs constantly and is not collecting water. We had it in the basement where it frosted up. Brought it upstairs where it ran and ran without collecting water. It was not like this last...
Sue, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
level
problem.
You also asked, "
do you know of a cradle to cradle product that lasts longer than this?". Unfortunately, I have no idea what you are talking about. Could you please explain? Thanks.
Jul 11, 2011 | GE AHG50LB / AHG50LD Dehumidifier
What order do the connections from numbers 1 to 6 go when connected to the coil pack ? e.g. 1 & 2 go to 1 & 2 of first coil 3 & 4 go to 3 & 2 of second coil 5 & 6 go...
TELL ME TYPE CAR MODEL AND YEAR OF THE CAR I NEED TO KNOW ALL YOUR ENGINE INFORMATION BEFORE I CAN TELL YOU COIL PACK PLUG WIRES LOCATION.
Apr 04, 2011 | Isuzu VehiCROSS Cars & Trucks
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
Mtd Bronco Rear Tine Tiller Logo
132 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
