My HD PVR 101-ST has an error code: Er09 when i press th ''ok'' button it shows Er01 when i press ''ok'' it shows 00-- and after a while it shows ER09 again. If i pull the power cord it starts the same way. Do you hawe any solutions? The suport at Canal digital said that it maby could be the powersupply that don´t delivers the right voltage. But i don´t now it sounds strange to me.
Hi, just got the same problem.
In my case it started not working well 4 days ago. Today I got a message on the screen asking whether I wanted to upgrade the software. I did and now I have this problem.
In my case I would say that canal digital customer service is quite bad
Posted on Jun 07, 2010
  • gbenaroya Jun 07, 2010
    Hi, solved it by luck.
    Turned it back on and pressed the menu on the remote repeated times. The system started
    Once the system asked me again if I wanted to upgrade the software I said NO!!
How to set up new hard drive DTR 6400T free view recorder
Try this;
1. Turn off the unit for 15 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the antenna input.
3. You will get an Er09 on the display. No output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote (confusing as there is no clue that this is what you should be doing, though Sagem support thought that the PVR should prompt you.
5. The box reboots in standby mode.
http://forums.digitalspy.co.uk/showthread.php?t=1028520
The hdd is formatted as it is needed, much like a Mac. It uses RAW not NTFS, FAT etc.
Dec 08, 2016 | Computers & Internet
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
· Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
I need an english manual for my hd pvr 101 st
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 12, 2011 | Televison & Video
Shows ER07 ER09 ER 01 Scrolls through 01 etc. and eventually shows ER09 SAGEM Model DVR 6200T/6400T
I had a very similar problem. On initially starting up it showed Pb03 then would cycle between er07 er09, er01 and counting up 00,01 up to 19 or so.
Nothing I did fixed it including turning it off for a long period and back on without the aerial.
Eventually I fixed it by pulling out the power cable while it was counting up and then on powering back up it started to initialise correctly. No idea what the problem was and why this fixed it but it might be worth a go. It didn't involve losing any recordings.
Jul 26, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
When i turn the box on there is a loud `whurring` sound and the box says` Er09` what do i need to do to fix this ?? Thanks
Hi I waent to your forum and followed some advice about the error code and now the box is working .... it was an update issue ... i needed to disconnect the aerial and then leave and then re-connect. Thanks
bren
Feb 07, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Er09 and Er07 black screened
Turn off the unit for 15 mins.
Turn back on with eveything connected except the antenna.
You will get an er 09 on the display.
Press OK on the remote.
With a bit of luck the box will reboot into standby.
Connect antenna and see how you get on.
Jan 07, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Hi :-) I also have P603 / Er09 / Er07 / 00-- Error messages, even after being unplugged overnight. Upon power application the unit clicks quite loudly 10 times in a row, then repeats this 4 times, before...
contact sagem 0835 0900316 technical support helpline you will need serial number of your box and the model a new power adapter was all I needed and can now watch all the programmes i had on the disc and thought i had lost
helen april 2010
Oct 11, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Error code 09
Er00 - The software that was available for upgrading was of an older or of the same version as the one already in the digital-box.
Er01, Er02 -The upgrade failed. Some information was missed out.
Er03 - The internal memory is not large enough to receive the upgrade.
Er04 - The signal was disturbed during the upgrade.
Er05 - Wrong type of data was received during upgrade.
Er06 - Not used.
Er07 - Access problem in back-up memory (EEPROM).
Er08 - Access problem in video memory.
Er09 - Can not find any data to do an upgrade.
Er10 - Poor or no cable-TV signal.
Er11,12 - Not used.
Er13 - Unauthorised data signals received by the digital-box.
Er14 - Faulty data signals received by the digital-box.
Pb01 - A problem in the ROM memory is detected.
Pb02 - Memory size is too small.
Pb03 - A problem occurred during start up (initialisation
problem).
Pb04 - Internal communication failure.
PbF9 - Hardware error identified during start-up
From elsewhere on the web:
3. You will get an Er09 on the display. On my PVR there was no output on the TV screen whatsoever (totally black screen).
5. The box reboots in standby mode."
Good Luck...
I also see some mention that if the above procedure doesn't work, try pressing "Menu" twice to see if that clears error 09.
Mar 05, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
I have the Onkyo 706 with remote RC-717M. My remote just suddenly started to malfunction. The volume up is turning it down and vice versa. The power button to shut the receiver off is doing the function...
Have you tried resetting the remote? According to the manual (page 101), press and hold the RECEIVER button, press the AUDIO button, wait approx 3 sec. until RECEIVER highlights and finally press RECEIVER again. Of course if you've programmed a remote control code for your PVR in the RC-717M, you'll have to do it again.
Oct 18, 2008 | Onkyo Audio Players & Recorders
Sagem freeview not working - says error 09
Unplug the box, leave for a couple of minutes, remove the antenna, and plug the box back in.
The display will show 00--. this cmay take a couple of minutes so wait until the box shows ER09.
When this happens, Press the ok button.
The box will reboot, and a messege will say the download was succesful
The box should now work, and may need retuning. it will take some time and rescan and when it finishes, it will probabably ask for a resacn again, select ok and it should now do it again,
Mine toppled over yesterday and it is now all ok
Jul 17, 2008 | Televison & Video
Televison & Video Logo
2,768 people viewed this question
Top Televison & Video Experts
Electro Med Services...
