Question about Maytag Neptune MAH5500B Front Load Washer
Waht does the Code FL and LO mean? And how do I fix it? The Start/Pause button keeps blinking, the door is locked and the cycle will not complete? I had an appliance repair man out yesterday to fix it who obviously was not Maytag certified. He charged me $189 and did not fix the problem. I am so frustrated.
  • donnamo521 Apr 25, 2010
    Model: MAH5500BWW
    Serial: B4990378EX
    Style: (Y) Y7909241
    I appreciate your expertise. If your reply with parts is going to cost an additioanl $12.99 please do not reply. I'm not sure how this works but I'm already out so much money on it.
    Thanks for your help.
  • donnamo521 Apr 26, 2010
    Very helpful!
    President:
  • 949 Answers
Sorry you are having trouble, here is what the codes mean.
LO means the door failed to unlock after 11 attempts
Possible causes:
Door lock solenoid
Loose wires to solenoid
Faulty door lock switch
Faulty door lock sense switch
Bad control board
The FL is the same set of symptoms.
From my experience the trouble is the lock solenoid has failed, and unfortunately most often when that does fail it takes the control board out at the same time. If you can get me the complete model and serial number from the tag on the back of the console I can get you the part numbers I suspect you need if that helps...
Posted on Apr 25, 2010
  • Philip Apr 25, 2010
    Sorry you are out so much, there are no additional charges from me for this.
    The part number for the control board is 22004446 and has a retail price of $230.41
    The part number for the latch assembly is 22004435 and has a retail price of $110.41
    Sorry to be the bearer of such bad news on this. You may want to call Maytag and see if they are willing to assist with the parts for you, every once in a while you may be able to talk them into sending them to you... worth a try.
    Their number is 1-800-344-1274
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Aug 20, 2016 | Maytag Neptune Washing Machines
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Receiving error code FL on washer display.
The FL error code means:
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
Dec 07, 2012 | Crosley CW6000 Front Load Washer
Samsung WF350ANR/XAA has an error code FL and door will not lock to start cycle
The FL Code means that the door failed to lock. Turn the machine off and restart the cycle. If this does not clear the error message and the machine does not return to normal, you will need to contact a Samsung repair service.
Jul 25, 2012 | Samsung WF337AA Front Load Washer
I have a Frigidaire front loading washer LTF 2140FS2 that will not start. I press the Start button door locks, press again the Wash Cycle light comes on. Then after a few seconds all the cycle lights...
Hi
Press and HOLD the Start/Pause and Cancel buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Daniel
Sep 25, 2011 | Frigidaire Washing Machines
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
107 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
