Question about Epson Stylus Photo R1800 InkJet Printer
I have a r1800 epson stylus , i have run all the cleaning and adjusting fixes in printer maintenance. Color is good but i have lines going accros photos that are about 1/16" and faded. Need help
    Problem Solver:
  • 15 Answers
A bit late from your initial request for help, but I also have the same printer. I found that removing the print head and cleaning it manually solved blocked nozzles.
You require a small screwdriver and some solvent cleaner.
Take out the 8 cartridges.
Turn the power off and disconect the power cable.
As you look in the cradle you will see some small screws, remove these.
The floppy cable that connects to the head is clipped in, un clip it.
The head can be now lifted out, pull the ribbon out of the head noting which way it came out. It simply pushes back in.
Now you have the print head in your hands, be carefull not to let the surface touch anything.
To clean it can be done in several ways, I use a solvent cleaner that is aerosol based, give it a good squirt, virtually soak it.
Whilst the head is removed clean the rubber wiper blade that is now visable.
Dont let the head dry out too much, put it all back togethor and run a head clean.
Your first prints might look a bit poor, untill the cleaning fluid has washed through.
Allways works for me.
Takes about 20-30 mins in total and is better than running lot of head cleans costing a small fortune.
Best of luck.
Posted on Sep 02, 2010
    Scholar:
  • 67 Answers
The problem is with the print heads. Unlike hp, which puts the print head on the ink cartridge, Espon inks are simply "tanks". The heads are fixed into the printer, and the ink just flows down to them. Thats make the only way to really clean them is to remove them--a very daunting task. The ink has a high glycol content--good for fast drying but bad for the heads. Try running a LOT of cleaning cycles (which uses a LOT of ink!). If you get them clear, they will stay that way if you practice printing something (test or demo page) at least every other day. Also, NEVER remove a cartridge until you have a new one to put right in. The residual ink in the fixed print heads will dry out if exposed to the air for even an hour or so.
Posted on Apr 25, 2010
Epson Stylus R1800 is not printing correctly. It is skipping spots leaving clear areas across the page. Changed all the cartridges.
your problem is not with the inks it is with the printhead... try running the maintenance and head cleaning... epson is notorious for print heads getting clogged!! good luck
Mar 31, 2010 | Epson Stylus Photo R1800 InkJet Printer
My printer stopped printing black color. I changed both black cartridges, but the problem didnt resolve.
Try going into the printer software and find "print head clean" or similar and run this through.
Jan 26, 2010 | Epson Stylus Photo R1800 InkJet Printer
I have an Epson Stylus R1800. How do I print bleed with it?
When you go to print, adjust the margins to zero. If it states you are printing outside the printable area, choose IGNORE.
Sep 30, 2009 | Epson Stylus Photo R1800 InkJet Printer
Anyone know how to fix banding in dark areas of photographs?
I see your problem. You need smap and eject adjusment (PF adjusment), using R1800 adjsument program. Try to find at indoreset.blogspot.com
Jun 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
Washed out prints - no color - not vivid
I just had the same problem -- go to epson.com and look under drivers and support. Select the R1800 and go to FAQS, there it will tell you how to resolve a driver issue that can cause this.
Good Luck!
Jun 24, 2009 | Epson Stylus Photo R1800 InkJet Printer
MacBook Pro Epson Print Driver Dilemma
your problem is about profiles. The gutenprint is the only way to print from intel to r1800, but this driver don't use the same ICC profiles. You have to use one of three solutions below:
1 the best, you have a profile calibrating device, you make a profile of your couple ink-paper and you convert your document into this ICC profile.
2 you convert your picture into your software in one of the Epson generic profiles (hey probably still are on your computer) and you print whithout color managment
3 (awful) you anticipate the color distorsion and you tune your picture to be bad on the screen but pretty good on paper.
Feb 03, 2009 | Epson Stylus Photo R1800 InkJet Printer
RED WON'T PRINT
Hi-
Try running a head cleaning from your computer, if you are using XP go to printers and faxes under control panel and right click on your printer icon then go to printing preferences then go to maintenance and run head cleaning cycles for 3x then print a nozzle again. if all fails cal epson and check for the warranty so that you can have it replace, coz chances are the nozzle for magenta is clog.
Hope this helps
Sep 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo R1800 InkJet Printer Logo
579 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
