Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Ponding of water after washing
The frigidaire dishwasher ponds water at the bottom of the unit after washing; how can that be solved?
  • Anonymous Apr 03, 2008
    Ponding of water after washing.I have done nothing but took apart the inside and found nothing that stops it up.
    I have puddling problem also.mine is not the stainless door one though,shouldnt matter.help.
    Sergeant:
  • 409 Answers
check the drain pump for any blockage. from the sounds of it, the pump does not dispose of the water completely. if there is nothing visible, replace the drain pump.
Posted on Sep 13, 2008
My abs light and the skid light is staying on
Hi K, Seems the wheel speed sensors are dirty or damaged due to where you've been driving. The remedy is to have diagnostic scan carried out, from which the defective unit or units will be identified and the appropriate action recommended. Regards John
Aug 30, 2012 | 2007 Lincoln MKX
Ffbd2407lm frigidaire dishwasher stops washing cycle?
Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
Aug 24, 2012 | Frigidaire Dishwashers
I have grit on my dishes especially my glasses. What should I try?
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Mar 31, 2011 | Frigidaire Dishwashers
Dishes are not getting clean
Mar 21, 2011 | Frigidaire PLD4375RFC Dishwasher
Firgidaire dishwasher MODEL FDB641RJSB leaves cloudy residue on dishes. Top spin arm does not seem to be rotating,
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 01, 2011 | Frigidaire FDB125RH Dishwasher
Frigidaire diswasher detergent dispenser
the first thing to make sure is that the incoming water temp is at least 120 degrees.the next thing to do is check your water level and pressure when running if the water pressure is not high enough then you may have to replace the main wash motor.
if you do not think there is enough water in the bottom of the unit after it has stopped fillng add a few more cups to bottom and continue the wash cycle.
if there is no change in the performance replace the main wash motor
Mar 14, 2010 | Frigidaire Dishwashers
My frigidaire dishwasher does not wash on the top
Insufficient water can cause your symptoms
Nov 02, 2017 | Frigidaire Dishwashers
Dishwasher fills with water... stops...(when it should be washing) then drains. Seems like timed cycle is working. justdoes not wash.
you have a sensor and it is restricted behind the bottom panel you see a rubber hose about 1/4'' in size remove and blow through it unless it a Bosh unit some how water gotten into the motor area this is cause by a plugged drain hose
Aug 22, 2009 | Frigidaire Dishwashers
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
113 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
