Question about Kenmore Dryers
Gas kenmore dryer, no heat . the gas heat does not turn on. i tried running it without the vent but no help.
    President:
  • 1,430 Answers
It could be several things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on Apr 25, 2010
My kenmore 600 gas dryer dont heat up. gas is on electricity its fine it turn on it works fine but just not heats up.
Disconnect the rear vent off the dryer itself and try again. If heat does work the vent tubing is clogged
Oct 06, 2010 | Kenmore 600 6962 Dryer
Kenmore 77904 doesn't heat
Check the lint build up inside the exhaust vents first and try again
May 09, 2010 | Kenmore 73952 Gas Dryer
My Kenmore dryer seems to have a mind of it's own on heating. Sometimes it heats very hot, sometimes little heat at all. It does not seem to matter what setting it is on, low, med, or high. Nor does it...
when was the last time you cleaned it out,try running it with the vent line removed,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is,if you have a shop vac put it on blow and blow off the motor and clean out the vent line and the outside vent,if the vent line is long i use a leaf blower to clean out the vent line,also is it gas or electric?next time send model number?if it's gas you could have bad gas coils,when they heat up they fail,clothes are warm at end of cycle.run the dryer for 15 to 30 minutes and check to see if the flame is still lighting if not bad gas coils.hope this helps
Feb 21, 2010 | Kenmore Dryers
I have a Kenmore gas dryer that the timer will not move and the ignitor will not glow. Both happened at the same time. What might this be
if you have the timer on auto it will not advance without heat,when the heat shuts off the timer moves,you could have popped the thermal fuse located on the blower wheel housing,if the lint filter is on top you have to take the vent line off and remove the back panel to get at it,if the filter is inside then the thermal fuse is in front to the right of the lint filter,this is mostly caused by a blocked dryer that needs a clean out,take off the duct that the lint filter slides down into and clean it out,vac out the inside of dryer where the motor is,and clean out the vent line,if it's a long run blow it out wiyh a leaf blower,you should do this once a year so the dryer runs correctly and clothes will dry faster,if it's not the fuse check the ignitor the sensor and the gas coils,when the dryer cools down and you turn it on and if there is heat for like the first 10 or 15 minutes then no heat it's the gas coils that are bad,hope this helps you
Jan 19, 2010 | Kenmore 63942 Dryer
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 20, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Kenmore 70 series dryer wont heat up and wont stop running
For a gas dryer, check the following
1. Gas valve coils
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
For a electric dryer, check the following
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jun 01, 2009 | Kenmore 63942 Dryer
Kenmore 70 series electric dryer runs but won't heat up?
Hi!!! If the unit is electric your heating element needs to be replaced if its gas then replace the coil boosters located on top of the gas valve..Good luck..
Jan 04, 2009 | Kenmore 73952 Gas Dryer
DRYER DOES NOT DRY BUT CONTINUOUSLY RUN
Run the dryer for a minute, then open the door and check for heat. If there is heat, the element is ok. If so, you've got a venting issue. If there is a restriction in the vent you won't be able to get as much air out, therefore you won't be able to get as much of the moisture trapped in the air out. The auto dry settings on some dryers require the operating thermostat to open to advance the timer. If there is a venting issue it may cause the dryer to cycle with the hi-limit thermostat instead. Of course, it should not affect the timed dry cycle. so if it won't advance there either you may have another issue. Try taking the vent off the back of the dryer and allow it to vent into the room. This may take care of both of your issues if the restriction is in the home venting, then you would need to sweep the home vent. It's also possible that the restriction is in the dryer blower housing. Without the vent hooked up, turn the dryer on and feel where the vent leaves the dryer. You should have a fairly strong movement of air, if not you'll need to disassemble the dryer and remove the restriction.
Jul 21, 2008 | Kenmore Dryers
Dryers Logo
340 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
