Question about Danby DDW497W 22 in. Countertop Dishwasher
Spray arm assembly does not spin in any cycle used
  • Danby Master
  • 43,501 Answers
Here is a tip that will help you...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 27, 2010
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
SOURCE: Upper arm does not spin
No I don't believe its the pump. I believe the lower spray arm is possibly split open on the side causing a loss of presure and flow to the upper arm and overloading the door seal. As well the loss of flow to the upper arm will resulted in it turning too slow.
Posted on Feb 22, 2007
  • 11 Answers
SOURCE: water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Posted on Mar 22, 2007
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
danromarris
  • 101 Answers
SOURCE: Lower spray arm won't spin
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Posted on Jan 22, 2009
Tablet keeps coming out of the dispenser on my hotpoint fdl 570 dishwasher on all cycles and falls on to the floor, result is that the crockery isn't always clean on the top tray. Machine is still...
Hi Jeanette,
Maybe I misunderstood your question, but the tablet is supposed to come out of the dispenser and fall into the bottom of the dishwasher. It needs to fall into the hot water in the bottom of the washer to dissolve. The dispenser releases the tablet at different points in the cycle depending on which wash cycle is selected. On a shorter cycle it will be released soon after starting. On longer cycles, there is usually a rinse first, so the tablet will be released a little later. There would only be a problem if the tablet wasn't being released, or wasn't dissolving completely.
There are a number of reasons for poor cleaning on the top rack. The most common are the upper spray-arm not spinning, incorrect stacking or overloading. If the upper spray-arm isn't spinning, there may be caused by a blockage in the spray-arm or the water delivery system, but, as the dishwasher is new and it's not happening every time, it's possible that the dishwasher isn't levelled correctly. The spray-arms aren't motorised, they use water pressure to spin, but they wont spin if they aren't balanced, i.e. the dishwasher isn't level.
You can check whether the spray arm/s are spinning by pointing them front-to-back, or left-to-right (so you can remember the position) and allow the dishwasher to run for a few minutes. Then open the door and check the position of the spray arms. They should continue to rotate slowly for a short while after opening the door, but if they're in the same place and static, they're not spinning. I'd suggest repeating this a couple of times to eliminate the possibility of them having stopped in the exact same place you left them.
If the spray arms are spinning, test the dishwasher with only a small load in the top rack. If the top rack comes out clean with a small load, you may be overloading it or stacking it incorrectly some of the time. There should be a correct stacking guide in your user manual.
Hope this helps. If you need further assistance, check whether the arms are spinning then post back.
Regards,
BElectric
Jul 03, 2011 | Dishwashers
After a regular dishwashing cycle, our dishes and glasses are not getting clean. They are left with a white film. We have checked and all holes in the spray arms are open. We have tried a rinse agent,...
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if you need more assistance.
Feb 09, 2011 | KitchenAid KUDR24SE Built-in Dishwasher
Glasses on top rack are dirty on outside of glass, looks like soap scum
Hi
Hope this helps... Please post back if more information is required.
Daniel
Feb 09, 2011 | Frigidaire PLD4375RFC Dishwasher
The top shelf is not getting clean. There is food residue on the glassware that was not there at the start of the wash.
The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back
2. Close the door
3. Start any wash cycle
4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Regards,
BElectric.
Dec 14, 2010 | Frigidaire Professional Series 24 in....
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Will not clean
I had the same problem with my Kitchenaid dishwasher. It would fill with water, heat up, and sound like the motor was running just fine. However, the bottom dishes would be poorly cleaned and the upper dishes would not be touched. Fortunately, my repair did not require pulling the dishwasher out from under the counter. The repair was done within the wash cavity.
I completely drained the water out of the dishwasher (if it hasn't ran through it's cycle). Use a turkey baster if necessary. I Removed the lower wash arm, upper arm supply tube and then started removing plastic cover parts until I worked my way down to a part called the "Chopper assembly". Torex screwdriver bits were necessary in my case.
The chopper assembly is a small metal screen, a metal blade and a plastic drive rod that spins the metal blade.
c9a1a9f.jpg Chopper assembly
In my case, the plastic part of the assembly was broken and the chopper was not spinning. The screen was plugged with food junk and water could not get past the screen to the wash arms. the spinning blade also ads a little pressure...when it spins.
the part is $21 online, but may run $30 at a local parts store.
Dec 27, 2008 | Maytag Dishwashers
I have an equator PLS600 and I can't seem to get it to work. I have tried the WikiFix to help a stalled dishwasher, by adding water and vinegar. When I put on the wash cycle it does not run. Even with the...
Give the spray arm a spin to make sure it rotates. It should spin freely. If not, remove plastic spray arm clip, flip it over, replace it, and try again. Make sure holes in the spray arm are clear of debris. Spray arm must be clean for it to spin. If spray arm does spin freely, remove spray arm clip, spray arm and the post assy (the thing the spray arm attaches to). Try your WikiFix again. This time add baking soda to the hole the post assy came from. Top it off with white vinegar. Leave it overnight. In the morning, stick your finger down the hole where the spray arm assy sat. You should feel a plastic thing. This is a propeller attached to the recirculation pump. You need to free it up. Get that thing moving with your pinky or a chopstick or whatever. Try the machine without the spray arm. You should get water blasting up from the hole. Reassemble the spray arm.
Nov 26, 2008 | Equator 20 in. PLS600 Free-Standing...
Lower arm spinning slow/intermittent
running with the door open indicates another fault that could be dangerous unless you have bridged the catch for testing only, water should flow fast and forceful at all times that it circulates, through both spray arms at once, you have to look for blockages in the system, is the waste outlet pipe high enough, this allows the machine to fill adequately so it doesn't pump intermittently, i doubt very much this is an electrical problem hope i have helped a little
Sep 25, 2007 | Zanussi ZT485 Built-in Dishwasher
Danby DDW497W 22 in. Countertop Dishwasher Logo
269 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
