Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Chasnge light for water dispenser
How do I change the light bulb for the water dispenser
  • GE Master
  • 4,654 Answers
Dispenser
Unplug the refrigerator.
The bulb is located on the dispenser
under the control panel.
Remove the light bulb by turning
it counterclockwise.
Replace the bulb with a bulb of the
same size and wattage.
Plug the refrigerator back in and you are ready to go!
Thanks, Sea Breeze
Posted on Apr 25, 2010
I have a Hotpoint American Fridge freezer model MSZ902DF
A google search will answer this question for you.
Sep 05, 2017 | Hotpoint Refrigerators
Amana AR2664bw dispenser lights
Are you talking about the inside lights are the dispenser lights?
Nov 01, 2008 | Amana Refrigerators
Side by side ice and water dispenser
Did you replace the bulb with one of the same voltage rating?
Seems strange that a new bulb should blow straight away, maybe it was faulty.
This sounds like a blown fuse.
Oct 13, 2007 | Frigidaire FSC23F7D Side by Side...
How can I fix a dim light bulb on an ice dispenser?
The dispenser bulb looks similar to a c7 christmas bulb or night light bulb but they are not the same. The dispenser bulb on some are 6 volt and some are 12 volt. The night light bulbs are 120 volt and will light very dim. Make sure you got the correct bulb from an appliance part dealer. They will need your model number of the fridge. Or check on line parts stores like www.vvapplianceparts.com.
Mar 04, 2016 | GE Profile Arctica 25.4 Cubic Feet...
How to change the light bulb in the outside ice/water dispenser
Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
The light on the outside door (where the ice/water dispenser is) won't turn off. It is dimmer than when you hit the 'light' button, but it stays on constantly when the door is shut. The 'light' button works and turns the bulb brighter, but when you turn it off, it just dims and doesn't go out. The light shuts off when the door is open and turns back on when its closed. Model Number MSD2456GEB
Posted by linsdesk on Aug 31, 2011
Aparajita Batabyal
  • 3,513 Answers
Re: The light on the outside door (where the ice/water...
Hi
Reprogramming your refrigerator to only light up when the dispenser is in use saves energy and keepsyour house darker at night. The light is controlled using the buttons above the water dispenser mechanism.Press and hold the "Lock" or "Lock Controls" button for three seconds to activate the controls if they currently are locked.Tap the "Light" button to switch off the light.Press and hold the "Lock" button for another three seconds to lock the controls from further changes. The light now only comes on when the dispenser is active.
If the above procedure won't work then this will be the cause of a faulty switch. This light switch is an integrated part of the dispenser control circuit board. This will require you, or your service tech to replace the entire dispenser/ice maker control board. It will be located just behind the dispenser fascia, mounted on a bracket. the actual light switch circuit is mounted on this board.
Try this procedure:-
Shutdown the unit for five minutes. Simply unplug the unit for this length of time. This will reset the board, and possibly, fix this fault if it is not to severe. If the shutdown dose not correct the switch action, simply replace the dispenser/switch control circuit board.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Jul 25, 2015 | Maytag Refrigerators
How to change the light bulb on the ice dispenser in the door?
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
First - Make sure the dispenser light switch is turned off. Now, that you have broken the bulb it is like having a bare 110 volt hot wire.
I recommend that for safety purposes you do not use either the ice or water dispenser and well as the chance of condensate from warm outside air getting into the electrical and burning out the control board or harnesses.
Get some electrical tape. Turn power off to the refrigerator at the breaker box or unplug the refrigerator. Then, tape over the broken bulb. Turn power back on to the refrigerator.
You may have a ice dispenser cup that you can remove or the dispenser frame for more ease of access.
You now may need a pair of needle nose pliers to remove the bulb.
You did not provide a model number so I can see exactly what you have. Your model number is on the inside of your fresh food section on a label on the upper inside wall.
May 10, 2015 | Kenmore Refrigerators
I NEED TO CHANGE LIGHT BULB WHERE WATER IS DISPENSED IN DOOR OF AMANA SXD26VW. PUT IN 12V - 6 WATT & IT BLEW THE BREAKER. WHAT SIZE BULB IS NEEDED. NO MARKINGS ON OLD BULB & NO OWNERS MANUAL.
It requires a 120 volt bulb. If it is a screw-base bulb, it's the same bulb as used in plug-in nite lights. If it's not a screw-in you'll need to go to an appliance parts store to the proper bulb.
Apr 23, 2009 | Refrigerators
Night Light...
look up inside the water and ice dispenser and after you see the bulb...replace it with same.
Apr 01, 2009 | Amana ARSE66MB Side by Side Refrigerator
Ice/water dispenser "shorted" out
You will have to get dispenser control outvto see what wires and switches may be burnt.
Nov 03, 2017 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
511 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
